It is currently Thu Sep 20, 2018 6:51 am
Hypertherm PM 65 Plasma arc issues and stops during cut
shejta
Postby shejta » Fri Aug 10, 2018 2:38 am
Dear,
I am running out of options. So I decided to ask help fromyou, dear experts.
I have plasma cutter with PM 65 source and I start to gettingissues during start of cutting when plasma is unable to make arc. You can see how it looks like in videobelow. Also thereis issues of stoping of arc on longer cuts. Air is clean and consumables are new. Power is also ok. Amperage do not make any difference.
I need your help and advice.
Best regards.
Samir
https://youtu.be/yH3CNWPBFJg
Re: Hypertherm PM 65 Plasma arc issues and stops during cut
Postby plasmanewbie » Fri Aug 10, 2018 10:58 am
Do you see any error codes on the LCD screen?
Using genuine Hypertherm consumables?
Does the electrode slide freely inside the swirl ring?
Is your ground clamp connected both at the material and the plasma cutter?
shejta
Postby shejta » Fri Aug 10, 2018 11:54 am
There is no error codes on screen. Also, consumables are 100% genuine, electrode is fitted properly and clamp is hooked on machine bed. We put new pneumatic valve and pressure sensor but it not solve the problem. Also, when arc misfire there is some ticking noise in pneumatic valve and LED diods blinking. Is there any other ideas. Thank you for helping me.
Best regards.
Samir
Postby acourtjester » Fri Aug 10, 2018 12:27 pm
electrode is fitted properly and clamp is hooked on machine bed, I think this is your problem you need to connect the work lead directly to the metal you are cutting.
Everlast PM 256 tig
WyoGreen
Postby WyoGreen » Fri Aug 10, 2018 4:00 pm
From watching your video, your torch is too high above the metal to establish an arc or do any cutting, but maybe the video is just for demonstration purposes. It acts like someone is rapidly switching the cutter on and off, so maybe that is the place to start looking. You could short the arc start leads right at the CPC connector on the back of the Plasma Cutter and see if the arc will stay on. This will tell you if the problem is with the plasma cutter or back toward your control equipment.
CNC Router table
shejta
Postby shejta » Fri Aug 10, 2018 4:17 pm
This is for demonstrating purposes. If I put file with for example couple holes and start cutting at piercing hight of couple mm ( machine is equipped with probing sensor to ensure piercing hight ) machine make couple holes correctly and after that misfire one hole. Sometimes plasma misfire couple holes in row. Also, when I made long cut quite often plasma shutdown arc in the middle of the cut. Air still going through torch but there is no flame. Also there is no and error or warning light. From my experience it looks that pilot arc is weak. There is no specific "boom" sound on ignition. Is it possible to be some problems with electric circuits inside. Thank you
WyoGreen
Postby WyoGreen » Fri Aug 10, 2018 7:20 pm
The air continuing after the arc stops is normal. This is to cool the consumables after arc shutdown.
There are many things that can affect the arc. As acourtJuster points out, a poor connection between the clamp and the material can affect it. Oil or Moisture in the air can affect it. Low air pressure can affect it. Worn or sticking consumables is another cause.
If you have a hand torch, perhaps you could do some manual cutting with it to narrow the problem down to either the plasma cutter or control equipment.
CNC Router table
shejta
Postby shejta » Sat Aug 11, 2018 5:33 pm
I tried with hand torch and results are mostly equal. I will try to clean clamp contact and test again. Also I will try to increase air pressure. Is there any other advice. Thank you all for the help.
Samir
shejta
Postby shejta » Thu Aug 23, 2018 2:52 am
It turns out that problems comes from moisture in the air. We tried with air dryer and everything works flawlessly. Thank you all.
Postby acourtjester » Thu Aug 23, 2018 10:45 am
Thanks for posting the solution many don't
Everlast PM 256 tig
Users browsing this forum: Google [Bot] and 10 guests
