Hello, I am automating a pipe plasma cutting process. The system has a feeder conveyor of 12 meter lenght, with an inverter and a geared three phase motor, and a similar conveyor to take off the cutted pipe. Between the conveyors we have a Motoman robot with the plasma. The feeding conveyor has a encoder to measure the lenght of the pipe.
I need to control the coveyors (they will move syncronized) to feed the pipes and give the order to cut to the robot. The robot will have the path for each diameter and bevel direction, I just need to give it the order "Cut", a diameter, and a direction (For the bevel)
I know there´s a lot of CNC soft to do that, my problem is in the communication between the PC with the soft and the inventer of the conveyor and the enconder. I don´t know if control everything with a PLC and give the PLC only the lenght of the pipe I need, or maybe CNC soft can control all the system??
Thanks for your help!
Robot plasma pipe cutting
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- ↳ Introduce Yourself
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
