It is currently Sat Sep 22, 2018 10:52 pm
Cutting/Piercing 1/2" Plate
W&W Designs
Postby W&W Designs » Mon Jun 25, 2018 2:58 pm
I had a guy ask me to cut out some 1/2" thick by 24" diameter circles for an entry gate. I told him I had never cut anything that thick, but that I would give it a try. I noticed that my Linux Command CNC sheetcam did not have a pre-loaded plasma cutting tool to cut 1/2".
Can anyone share with me what cut settings you are using to cut 1/2" plate?
I have a Hypertherm 45 plasma cutter.
tnbndr
Re: Cutting/Piercing 1/2" Plate
Postby tnbndr » Tue Jun 26, 2018 9:53 am
Go to Hypertherm site and download the manual, there are cut charts in there for starting settings. Do some test cuts and adjust accordingly.
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Charlie10
Postby Charlie10 » Tue Jun 26, 2018 10:56 am
I used the recommended settings in the manual. Although mine is a bit different than posted above. I had to adjust the arc voltage some. Just be careful that you have long enough lead ins that you are not running over your slag pile from piercing. Because it blows a good amount out the top and I kept knocking the torch sideways.
W&W Designs
Postby W&W Designs » Tue Jun 26, 2018 1:08 pm
Charlie10,
Do you have a Hypertherm 45? I am wanting to know if it can peirce the 1/2" material or not.
Thanks for all the good information!
djreiswig
Postby djreiswig » Tue Jun 26, 2018 1:35 pm
We have good luck with the ramp pierce in SheetCam. Set the lead in to the material thickness and the plunge rate the same as the cut speed so it plunges at a 45 degree angle. Use a short or no pierce delay so it starts moving away from the slag pile immediately.
Charlie10
Postby Charlie10 » Tue Jun 26, 2018 2:29 pm
I have the Powermax45 XP, yes. And it does pierce, yes. But like I said, you'll get a decent amount of slag on top of the sheet around where you pierced. As long as the the end of your cut or the cut from a part nested next to it doesn't run over the slag pile, you're good. I'd give the lead-in at least 1/2" as djreiswig said. I didn't set mine accordingly the first time I tried and it gave me all sorts of headaches.
SeanP
Postby SeanP » Tue Jun 26, 2018 6:20 pm
I have done a fair bit of 12mm with the old 45, it will pierce it, I have pierce delay around 1.4 secs and pierce height 3.9 to 4mm.
The duramax torch upgrade is definitely better on the old 45 but the slag pile can be a problem.
Powermax 45 with Duramax torch.
R-Tech 210 Tig, Jasic 250 mig
Sheetcam, Scanything, Coreldraw X8, Solidworks
Table build gallery
Postby jimcolt » Tue Jun 26, 2018 7:07 pm
Yes , the Powermax45 can pierce 1/2" if you follow the specs in the cut chart posted by Charlie 10. the pierce height and pierce delay are key. Cut quality on 1/2" at these specs is very nice. Jim Colt Hypertherm
W&W Designs wrote:Charlie10,
Users browsing this forum: No registered users and 10 guests
