It is currently Tue Jul 17, 2018 5:03 am
Water Filter Advice
Jfile
Water Filter Advice
Postby Jfile » Thu Jun 07, 2018 11:13 am
I'm getting a new table in a few weeks and was looking for advice on a good water filter. I have an automatic purge valve on the bottom of my compressor and I have a small inexpensive 2 stage filter just a few feet after the air leaves my compressor. Those seem to do a pretty good job but there will be about 25 foot of line from that point until it gets to the plasma cutter and I feel like I should have additional filtering at that point. What would you guys recommend? Thanks in advance for any assistance.
Re: Water Filter Advice
Postby acourtjester » Thu Jun 07, 2018 1:07 pm
What you want is really an air dryer, many here use the refringent type or the desiccant type and other use a series of tubing and fans to cool the air.
These help to have the humidity in the air drop out and return back to a drain point.
Do a search for air dryer here and you can what is used.
Everlast PM 256 tig
Jfile
Postby Jfile » Fri Jun 08, 2018 9:35 pm
Thank you. I will do some research on it and see what I can find.
djreiswig
Postby djreiswig » Fri Jun 08, 2018 10:21 pm
We have one of these from Harbor Freight.
https://www.harborfreight.com/compresse ... 40211.html
rcecarbldr
Postby rcecarbldr » Wed Jun 20, 2018 9:25 am
I was gun shy about buying the Harbor Freight unit as some of the feedback isn't positive. Poorly assembled, freezing up, etc, etc. I bought this Schulz unit off Ebay for $725 to my door and man is it nice. I haven't hooked it up yet as I'm waiting for stainless steel whip hoses to arrive and a coalescing filter that will go between the cooling manifold I made and the dryer.
rcecarbldr
Not sure why the pic is showing sideways but if you click on it, it shows upright.
djreiswig
Postby djreiswig » Wed Jun 20, 2018 10:14 am
I used hydraulic hoses when I installed mine.
rcecarbldr
Postby rcecarbldr » Wed Jun 20, 2018 10:21 am
Jfile
Postby Jfile » Wed Jun 20, 2018 6:58 pm
Thanks to all who have replied. I think I have decided to go with one of air dryers not too far from the plasma cutter and then add one of the motor guard filters right behind the plasma unit. I read several good reviews on the Harbor Freight dryer so I'm thinking about giving it a try. Wasn't planning on spending that kind of money but from everything that I've read, you can't go wrong with multiple methods of filtering and drying the air used for cutting. Being a beginner, I want to avoid any thing that might make it more difficult to produce good clean cuts.
Thanks again for all of the advice.
djreiswig
Postby djreiswig » Wed Jun 20, 2018 9:53 pm
rcecarbldr
Postby rcecarbldr » Thu Jun 21, 2018 1:05 pm
I'm not going to lose sleep over $24 and I doubt my air system will ever exceed 200psi. Plus the stainless is prettier. LOL
djreiswig
Postby djreiswig » Thu Jun 21, 2018 5:51 pm
Works for me. ;)
Users browsing this forum: No registered users and 6 guests
