Can someone explain what is happening with these cut paths? We recently upgraded from 3.11 so we haven't seen this issue before. Thanks!
Michelle
Cut path problem
- rdj357
Re: Cut path problem
If you upgraded you should have advanced design - go to the offset/convert tab and make sure you have exclude crossovers checked. Also double check your kerf setting, for most thin gauge materials that I'd expect to see these cut from, it's close to .045 - be sure to enter the whole kerf, unlike 3.11 it will automatically only offset half the kerf distance.
I cleaned up the paths a little, the E has a loop on it that's in the font so it should be trimmed off and relinked.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
That's exactly what it was! Thanks so much for taking the time to help me!
- rdj357
No problem, any time!
Robert Johnson
Robert,
Thank you so much. I found you Youtube videos this morning. I have been having this same type of issue. I appreciate your help. Is there a chart somewhere that provides reference examples for settings? I had a chart previously for the 3.11 software, but I cannot find one for the new Design Edge.
Best Agricultural Regards,
Johnny D. Viebrock
Johnny D. Viebrock
- rdj357
Johnny,
I'm not sure there is a reference and I've been trying to have time to make the next video and that's going to be the exact topic. As soon as I have some of these 'fires' put out I'll get it done and should be a help!
If you're talking about things like I cut height, speed, etc. then the best place to get those is the cutter manual. If you have other questions or need a point of reference, feel free to shoot me a text at 918-457-0289. If a phone call is better then let me know and I'll try to get to a stopping spot where I can take your call!
Robert Johnson
