It is currently Fri Mar 23, 2018 10:29 pm
Fire pit metal gauge
Postby moosetracks » Mon Jan 29, 2018 2:13 pm
I am planning on making a fire pit but I am not sure which gauge metal to use. Any thoughts, recommendations?
Re: Fire pit metal gauge
Postby tnbndr » Mon Jan 29, 2018 4:43 pm
I typically use 10 gauge or heavier. If flat bottom I used 1/4" on the bottom and 10 gauge on the sides.
LDR 4x8, Scribe, DTHCIV
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
Postby sleepyweezle » Fri Feb 02, 2018 6:29 pm
I use 10 gauge for my fire pits
Postby plasmartist » Tue Feb 20, 2018 6:52 pm
I exclusively build firepits, and the gauge of steel depends heavily on your design. The majority of my pits are constructed from 10 gauge and some are 3/16" to make them very durable, but in my tests I have used 12 and 14 ga with no problems at all. in fact, I have kept my 12 and 14 ga versions for personal use to test their longevity and both are holding up just fine over the last year with many fires in them. Again, your design work is crucial, and using lighter gauges does require bending the material in key points to make it more rigid and resistant to warpage.
Postby bigworm36 » Tue Feb 20, 2018 7:42 pm
I have made a bunch from 3/16 thick with no issues probably a little thicker than needed.
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
Millermatic 211
Users browsing this forum: No registered users and 6 guests
