Has anyone made animal benches like these
What is the best way to attach the boards and make the bench stable from side to side? Weld angle iron along both sides? I dont have a design yet just saw these pictures in UK. Wondering if it would be better to design a metal back and bench seat?
Re: Has anyone made animal benches like these
i would put 3- 1 in pipes across front middle and back under wood should make it pretty rigid
That is a b great idea.
Look forward to seeing what you come up with
The 45-degree pieces you see in the last pic are there to keep it stable side-to-side. To attach the wood to the sides, you could either bend a continuous piece and weld it to the side, or use individual tabs. I'd probably go with the continuous piece to support the wood better
Those are pretty neat!
Look great, simple clean design.
