Rattle Can Paint Shaker
Has anyone seen or know of a DIY shaker that can shake several (up to 6) rattle cans at the same time ?
I have tried several DIY attempts at making something but not muck luck, open to any thoughts you might have
GoldWinger
GoldWinger
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
- rons
Re: Rattle Can Paint Shaker
I want one too
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
If im needing to shake 6 spray paint cans im getting out the paint gun.
You could start with Harbor Freight's 1 gallon paint shaker:
https://www.harborfreight.com/pneumatic ... 94605.html
You can shake up to three rattle cans as is. I would look into adding a jig to hold six cans, if needed.
HTH
Paul
HTH
Paul
I have never tried putting a rattle can in a paint shaker. It is my understanding the can can't stand the vigorous shaking action and they rupture. NOT OSHA RECOMMENDED. Maybe if the motion were slowed considerably it would be safe. Myself, I wouldn't even attempt it.
- lockeyone
I think since the Harbor Freight one runs on air you can easily slow it down to a reasonable shaking motion.
Epilog Mini 24 60watt, 2013
I bought the HF shaker years ago just for rattle cans and I've never had a problem. Common sense wins over OSHA in this case.
Allen
Allen
- 99guy
abmetal wrote:I bought the HF shaker years ago just for rattle cans and I've never had a problem. Common sense wins over OSHA in this case.
Allen
ditto
TruCutCNC Series1 Gen2 4x8 water
TruTrac THC
Powermax 85 . M85 Torch
TD A120 . SL100SV1
Mach 3 . SheetCam . CorelX6
TruTrac THC
TD A120 . SL100SV1
- tnbndr
Anyone else on here use this?Here's a tool for one.
I bought one a year ago, couldn't find it so bought another. First one broke at the tang where it enters the sawzall after about 20 cans. Second one broke same place after only 4 cans. Contacted the owner and he claims no one else has this problem.
Always just me!!!!
HF shaker has work for me for years with no problems
Many cans a week
I did see the price went way up
Many cans a week
Hypertherm 65
Hypertherm 65
I know this isn't a shaker, but it has been working for me for several years... I have an old "rock tumbler" designed for 2 drums and it is just the perfect length for a can of spray paint or quart cans of paint. I start to tumble paint as I am prepping for paint... give each cam 5-10 minutes initially if I need multiple cans. End with the can I start spraying with and put another one on a second time. By the time I use up one can the next is ready. Definitely noticed fewer plugged nozzles versus just hand shaking.
Jim
looks neat and they still sell them on eBay
