Just updated my Powermax 1000 to a Duramax Retrofit MACHINE torch. I have seen that the 45XP can Mark - was curious if my updated setup can mark.
If it can mark - what do I need and what kind of marking quality should I expect?
James
Upgraded Powermax 1000 to Duramax - Can I Mark?
Re: Upgraded Powermax 1000 to Duramax - Can I Mark?
I don't know if you can get the marking consumables but I don't think the 1000 will go down to the 10A stting required to do the actual marking. JC and jump in and expand but one thing that changed on the XP was being abole to adjust it down below 30A
Oh - mine only goes down to 20 Amps.
I'd love to see someone try it at 20 amps. Really curious.
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
Marking with decent quality requires about 10 to 12 amps, any more and it will be more of a deep gouge in the material with too much heat input. You can buy the marking consumables (nozzle and shield) and they fit the Duramax torch, however the results would likely not be good! Jim Colt Hypertherm
Thanks for the input - was at least worth checking into.
James
James
