Ohmic question
Ohmic question
So I picked up a used plasma table setup about a month ago and I’m planning on converting it to ohmic my question is it already has a floating head setup on it but it’s pretty cheap so my plan in to yank that off and put a break away torch holder on with the ohmic would that work fine or should I order a different floating head for back up?
Re: Ohmic question
Totally depends on what table (brand, model) what electronics and cnc control, what software and what plasma. If you can provide more info we may be able to help! Jim Colt Hypertherm
Re: Ohmic question
The table is an older 4x8 router table that was converted over to plasma, it’s running the CandCNC dragon cut stepper setup and for the cutter it’s using a Hypertherm 45 not the xp45 though.
I’m also building a water table for it aswell I no the ohmic can be fussy with water so Im still on the fence about going this route over a floating head with voltage height control.
Re: Ohmic question
Any ohmic will miss or false with a water table. The floating head is there to be the backup for the Ohmic (mechanical touch off) . If you don't mind picking up and remounting the torch head (better make sure it has breakaway sensors or it will just drag it around the table with the torch on) every time it misses then you can use a semi rigid mount. Better make sure the breakaway mount will come off on a missed touch off or you will be buying torch barrels !
There is a plugin Ohmic sensor for the Bladerunner Plasma controller.
