What Z axis is everyone using?
I built my own table using a gantry kit from ppllc and electronics from candcnc. I have been cutting for the last 6 months but have had an illusive random problem with my z axis. I have come to determine that the pitch of the z axis provided by ppllc was too fine, so to maintain 100 ipm on the z, the motors were running too close to their max rpm and stalling on startup and changing direction. Turning my velocity down to 70 ipm helped a little but the problem still occurred, then finally I took it all the way down to 50 ipm and I think I am in the clear, but I ultimately don't want a my z to run at 50 ipm bc whats the point of paying so much more for a decent dthc. So I am in the market to replace my z axis. I have researched a few brands, but to avoid tainting the water, I want to hear what others are using and how much you like them, or what you would have preferred. Thanks.
Re: What Z axis is everyone using?
I have the same setup, I haven't had a problem running 100 ipm. Are you sure you have the correct steps per inch value? When you jog the z-axis 1", does it actually move 1"?
At one point PPLLC had offered a Z with a 12 TPI pitch that results in 23,000 steps per unit. If you use the max RPM of the motor around 600 RPM you end up with about 50 IPM max. Its like being stuck in first gear and you motor will not do more RPM to get you to 100 MPH
The lead screw can be replaced with a recommended 5 TPI then 100 is easy to get. Steppers have a definite RPM VS torque curve and at some point they lose so much torque they can no longer lift the load.
Tom hit that on the head with the 12 TPI issue. Where would one find the parts to update it? Is it something that ppllc would sell? Here's the model I have for reference.
- edclayton1
If you are looking for something different, take a look at the Velox Z axis. I bought two of them so far for two different machines and they seem to be really well built. I found them on both their own website and on ebay. Some of them are made for plasma and some are made for routers with slightly different spec.'s
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
