It is currently Thu Jun 21, 2018 10:23 am
Plasmaspider.com web site / bugs???
exapprentice
Postby exapprentice » Mon May 08, 2017 12:55 pm
Hi every one just throwing this out there as I seem to be having problems with bugs on this site :shock:
I keep getting pop up screens that take over the page, I only get them when on the "plasmaspider web site" nowhere else :!:
normally when viewing new posts.
Am I the only one :?: if so it must be a virus on my PC but why only on plasmaspider :( and not on any other sites I visit :?
I have run the anti virus and malware software but cannot find anything
Best Regards to all
Exapprentice :D
(Pete)
_Ogre
Re: Plasmaspider.com web site / bugs???
Postby _Ogre » Mon May 08, 2017 1:27 pm
i have not had an issue
try clearing your cookies
little blue choo
Postby little blue choo » Mon May 08, 2017 1:52 pm
No problems soon far. Will let you know if they start.
Rick
Rick
Arclight 9600 4x8 table
Postby acourtjester » Mon May 08, 2017 4:16 pm
All workie fine here
Everlast PM 256 tig
Old Iron
Postby Old Iron » Mon May 08, 2017 6:00 pm
I've had no issues
Gamelord
Postby Gamelord » Mon May 08, 2017 6:52 pm
No problems here. You most likely have Ad-ware or Malware on your computer and the site with all the banner ads happens to trigger it.
Here's what I suggest, download Malewarebytes at the link below:
https://www.malwarebytes.com/
You do NOT have to purchase, just use the FREE version. The Purchased version is great because it does everything real-time without you having to manually scan but If you don't want to purchase you don't have to, you will just have to manually run the scan whenever you think you have something installed or start getting popups.
Install and run the scan, it will pull up everything that is backlogging your system and causing massive pop-ups and slow internet. Once ran, DELETE everything it finds.....I have been using it for over 10 years and have never had it delete anything I needed.
Once deleted, restart your computer and you should be good to go.
Postby tnbndr » Tue May 09, 2017 8:08 am
I don't have any issues other than the banners don't show on my computer. I just get a blank white space where they belong.
PM45
Miller 211
RW 390E Slip Roll
Postby acourtjester » Tue May 09, 2017 10:12 am
You may have an ad blocker set up to do that I do and have the same screen :D
Everlast PM 256 tig
szextreme
Postby szextreme » Thu May 11, 2017 7:43 am
Only problem I have on this site is I have to scroll down an entire page to see the first post/index? anyone else having this problem? quite annoying!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinary!
exapprentice
Postby exapprentice » Thu May 11, 2017 9:00 am
May I make a suggestion :?: Maybe "admin" could create a section for comments / improvements for the "Plasmaspider" web site ;)
its only a suggestion :roll:
Best Regards to all
Exapprentice :D
(Pete)
Gamelord
Postby Gamelord » Thu May 11, 2017 7:30 pm
szextreme wrote:Only problem I have on this site is I have to scroll down an entire page to see the first post/index? anyone else having this problem? quite annoying!
This may be a setting in your profile. Go to your profile (should be located on the top left of any page just under the search field, click the down arrow on the far right and select "Profile"), then click the "Board Preference" tab. From there you should be able to select "Ascending" or "Descending" for the "Display Post Order Direction".
Hope that helps.
SeanP
Postby SeanP » Fri May 12, 2017 5:41 am
Use the little button as below to go to the last post.
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
szextreme
Postby szextreme » Thu Jun 08, 2017 12:21 pm
Thanks for the input guys, but what I am talking about is where usually adds and whatnot are when you open up the site its completly blank and I have to scroll down an entire page of white before I see the first forum
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
Gamelord
Postby Gamelord » Thu Jun 08, 2017 9:09 pm
You probably have an app or program installed like AdBlocker. These programs block out banner ads so you don't see them. The blank space is the allocated space for the ads that you don't see. Check your browser settings and see if you have an adblocker program, if so, turn it off and see if that fixes the issue.
Users browsing this forum: No registered users and 8 guests
