just joined! quick question about inkscape and bitmap..
hey yall, just wanted to say thanks for the much needed information. so excited to get started (picking up my table Saturday) my question is about bitmap in inkscape. I have done images off google just to grasp an understanding of how to do it. I have my business logo I have been trying to bit map and make a dxf. I just need a little guidance on how to get a more straight, non pixelated image the edges are also really rigged. I keep getting fairly blurry lines, this image was on the back of my shirt and I figured I could get it to work. I go to bitmap brightness cutoff. threshold at .600 ...if anyone has any tips on this that would be greatly appreciated!!
Millermatic 252
Hypertherm 45xp machine torch
Eagle 4x4
Mach3, sheetcam, adobe il, inkscape
Proma 150 floating head, Quincy 5hp 60gal, 3 stage dryer.
Eagle 4x4
- tnbndr
Re: just joined! quick question about inkscape and bitmap..
I can't help you with Inkscape but would suggest that design lends itself to a complete redraw from scratch. You must know the font used if it is your design so I would just do the text fit to a curve. The welder design is already in dxf format on this site in the file sharing section somewhere. Put all the pieces together in a drawing and save as dxf or svg and proceed to process for cutting.
IMHO you will end up with a much better file.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- steel 35
(510) looked pretty good to me, that's usually a good place to start.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Will this work?
Change the bitmap mode to grayscale then adjust contrast and brightness. Open with Inkscape and do the svg save.
- little blue choo
Were you planning on doing this as a multi layer sign? As is you will have about 22 pieces in the welder alone.
Rick
Rick
Rick
Arclight 9600 4x8 table
Thanks y'all! Great ideas, I'm sure that svg file will work, yes it will be a multi layer sign. I just needed a little guidance
Millermatic 252
Eagle 4x4
Eagle 4x4
Millermatic 252
Eagle 4x4
Eagle 4x4
