Cut length help
Cut length help
Ok I'm haveing a major brain fart. How do I find the cut length of a part? I am using torchmate a software and coreldraw too, I just can seem to find where it would tell me.
Re: Cut length help
Have you thought about Google
I found this with one search
https://community.coreldraw.com/talk/co ... 44/t/20856
Re: Cut length help
Do a job report in Sheetcam it will tell you.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: Cut length help
yes i have done a google search, and have bought the macro for coreldraw but it is off and doesn't give accurate info.
i dont use sheet cam and have no idea how to use it.
Re: Cut length help
Even the demo version of sheetcam will do it. Just import your image, run operation - plasma cut on it. Click file, job report and then ok after you select your options. The full report has everything you would ever want to know about your drawing on it.
I run the demo version on my home computer and do reports with it before I take it out to the garage and run it through my licensed version for the gcode.
Re: Cut length help
Wouldn't Inkscape show it.
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
