It is currently Tue Mar 20, 2018 3:32 pm
Lifting torch Head
Trucut CNC Hardware discussion forum
Lifting torch Head
Postby hoodman_unarfmed » Fri Mar 31, 2017 11:25 am
Have a Trucut machine. My problem is that it will cut be cutting normal and then out of no where the torch head lifts higher and then it doesn't cut through just ugly slag melt lines. Curious if anyone knows why it does this and what I can do to not do it. Thank you.
Jacky Elliott
Re: Lifting torch Head
Postby Jacky Elliott » Fri Mar 31, 2017 3:15 pm
So many things can cause this. Everything from stuck consumables to THC issues. When this happens, what is your arc volts actual and set volt? I recently had an issue with air flow causing my consumables not to operate correctly. Check your consumables and make sure your electrode isn't stuck. It must be free. Try to figure out any symptons that might point in any direction. From the sounds of it, it is a intermittent fault that comes and goes, usually settings are not an issue for this type of problem but don't rule it out.
What type of torch do you use? Speeds, set volts, amps? Try to pay close attention to what is going on exactly with it when this happens. Is it localized to one area of your table or random? Loose connections? Check all your connections to see if you can find a loose connection somewhere. I'm definitely no expert but hope this helps.
Postby jimcolt » Sun Apr 02, 2017 1:27 pm
I suggest contacting TruCut CNC. They have very good support for the cnc plasma machines that they build and sell. Tell Cindy or Richard that Jim Colt sent you!
Since torch height control is controlled by arc voltage feedback...there are a lot of things that can affect the height / voltage relationship, most issues will cause the torch to dive into the material.
Diving Torch:
- Poor work cable attachment to the material being cut
- Low torch cut air pressure
- Worn electrode, worn nozzle (can often still be used if you set a higher arc voltage)
-Arc voltage setting too low. Increase arc voltage to increase height.
- Improper setting in software for freezing height during slowdown for fine features, corners, etc.
Rising torch:
- Arc Voltage setting too high
- Incorrect setting in software
- High Torch cut pressure (adjust according to manufacturers recommendation
- Issue with Plasma voltage feedback connection (feedback voltage ratio too low)
Best regards, Jim Colt
Postby RawFabRobb » Thu Sep 21, 2017 11:52 am
Did anyone figure this out? I'm having the same problem.. THC is fine.. I have to reset my torch height offset almost every time I change sheets and halfway thru a 10' sheet it starts to go higher that the set pierce height. Talked to Darius? At Trucut.. Not much help. Ross is sick. Manual says offset should be -.5 to -.7 ish... Factory was -.3 I'm at -.24 to get correct pierce height on 16ga.. Any help would b great
Postby acourtjester » Thu Sep 21, 2017 12:33 pm
you may have a bad switch if this is using a floating head switch. Ohmic sensors do not have that much of an offset if any.
Everlast PM 256 tig
cindy carlisle
Postby cindy carlisle » Wed Oct 25, 2017 9:14 am
Thanks for the call, Jim is so right, calling the manufacturer is the easiest way to resolve the issue.
We are always there to help our TruCut CNC owners. All they have to do is call.
Return to “Trucut CNC”
Users browsing this forum: No registered users and 0 guests
