Best way to cut angle iron w/table?
I'd like to use my table to blow holes in some angle, then cut it to length. I'll have the top surface horizontal/flat when the holes are blown. I'd then like to rotate it "angle up", like a teepee, and cut it. It's 2"x2", 1/8" angle.
Any suggestions on the best way to do this? Would I start the arc on some scrap. 125 material (beside the angle) to engage the THC, then let it climb the angle? Any suggestions on THC sensitivity, etc?
- SeanP
Re: Best way to cut angle iron w/table?
I find those sort of parts easier to cut first on the bandsaw and then jig up on the table to do any holes.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- Marty
14" metal saw/chop saw...for occasional use HF is fine.....faster and cleaner cuts than trying to cut angle iron with a plasma table..simple, fast and cheap solution
I have done many several fab/weld jobs cutting and welding structural steel with this saw...or get a metal blade for a reciprocating saw....
Ignition Metal Art Design
Give a man a fish and you have taught him where to come for a fish; Teach him to use Google and the Search Engine on Plasma Spider and he will be able to learn more than you could ever teach him yourself
i agree with others, not worth trying to even set up to attempt to try angle. if its possible i wouldnt want to screw up my torch or knock pieces around and mess cuts up anyway. look on craigslist even for a small cheap horizontal bandsaw. i got the harbor freight type one for 65 bucks with a few extra blacks and used it a bunch before getting a much larger better grade saw. chopsaws work but i personally hate the sparks hassle of pulling it out.
Check out the Evolution Rage saws- they cut cleaner, smoother and faster than the abrasive cutoff saws, and without the spark
I do a lot of this type of work what I do is bandsaw to size then cut on cnc
lets say we are cutting a 4by12 peace of angel iron
I will take a sheet of 1/8 then cut a 4 by 12 Square In it then I put the angle iron into the 4by12 opening on the 1/8 sheet now I have my jig I hope that make sense for you
- steel 35
More cool stuff thanks again!
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- Gamelord
- 4.5 Star Member
Or you can get one of these....
- Marty
or better yet....these demolition Shears are on sale now at Harbor Freight. Find a 20% off Discount Coupon somewhere, and they are only $2,347,387.00 !!
How do you initiate / keep thc functioning properly on the slope?HaasMetalDesigns wrote:I do a lot of this type of work what I do is bandsaw to size then cut on cnc
I do not cut them on a slope I cut them on the flat
I see. That's how I plan on cutting mine. Your jig idea sounds good, thanks for the info!HaasMetalDesigns wrote:I do not cut them on a slope I cut them on the flat
