Hello everyone,
A few months ago I bought Dan Roberts' (I Believe he was known here as Dano) PlasmaCam setup, including the computer. There are hundreds of designs but I have no idea on how to use the software. I don't know if there is supposed be a disk with a tutorial on it or if it's still hiding somewhere on the drive. If anyone can help it would be greatly appreciated.
Also does anyone know where I can get a water table?
New user and I need some help.
Re: New user and I need some help.
You may try here, you will need info from your table, (serial number) to get help from that tables users.
https://owners-community.com/login_pc.php
- WyoGreen
Welcome Knight....,
I'm glad to see someone ended up with Dano's table. I went over to Laramie and looked at his stuff and ended up buying his powder coating equipment. I already had a table, so I had no need of his. If I remember right, it was a Plasma Cam table, and I think you can change the registration of the table from Dan to yourself on the Plasma Cam site, then you should be able to find answers to some of your questions there. There was a post on here about changing the registration.
As far as a water pan, I had mine bent up at a local metal crafting shop here in Cheyenne. It shouldn't be that hard to get one fabricated to fit your table.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
