Anybody have any luck cutting woven wire?
I've got a need to cut some of this 1/8" and thought it would be the hot ticket to plasma.
Cutting woven wire
- 9er
Cutting woven wire
Arclight Arc Pro 12000
Hypertherm PM85
Hypertherm PM85
- Gamelord
- 4.5 Star Member
Re: Cutting woven wire
Throw a piece of scrap strip where you need to cut and cut them both at the same time.
Torchmate CAD
Torchmate CAD
- 9er
Have you done that? Sounds like a really clever idea.
I'll try it.
I'll try it.
Hypertherm PM85
Hypertherm PM85
If your plasma cutter has an expanded metal mode....switch it on and cut away. Have cut this many times with good results.
I do it quite often. It makes fab time a lot quicker when messing with that crap.
- 9er
Great! I have a PM85 and yes, it has the expanded setting.
I assume some trial and error but I suppose I'll start with a 1/8" setting since the wire is 1/8" dia.
Hypertherm PM85
Hypertherm PM85
- 9er
Ok, got tied up but want to give this a shot.
So I've got a PM85 on an Arclight table.
I just want to cut straight lines or boxes.
Would I load whichever tap file I want to use as usual, turn off the THC and cut as usual?
Hypertherm PM85
Hypertherm PM85
- 9er
Ok, so with some trial and error, (lots of error) I got it cut. Here's a list of a few things I needed to do.
*Set PM85 to expanded
*Turn off DTHC- in Mach3
*Set DTHC to manual- in Mach3
*Program power to twice the thickness of the wire. (it would not cut through overlapping intersections, and that makes sense to me)- in Sheetcam
*And I needed to sneak in and out a thin strip of sheetmetal for touch off. Otherwise, it would dive in to the hole on touch off and then drag the piece around (gottta be quick!!!!)
It works, thanks for all your help and hopefully this can help someone else.
Hypertherm PM85
Hypertherm PM85
Did you have to disconnect your hub from your hypertherm, in order to cut in expanded mode?
- 9er
No, I didn't physically disconnect anything. Just turned the knob to expanded mode.motoguy wrote:Did you have to disconnect your hub from your hypertherm, in order to cut in expanded mode?
Hypertherm PM85
Hypertherm PM85
