I thought I had a file for one of these, but I can't seem to find it. Not having good luck with the search function tonight, either. Anyone happen to have a good file for one of these, or a link to the correct thread?
Knockdown octagon firepit
Re: Knockdown octagon firepit
Here is a knockdown Hex Fire Ring I did with only "sides". The material is 3/16 thick x 12" high x 24 " long.
Six of them will make a ring about 37" across, 7 about 44", and 8 about 50" across.
Deer, bear, moose and slots are attached. Mix and match.
I also designed a 4 sided knock down fire pit with a bottom plate and feet. Just do a search on my name(handle) and you should be able to find it.
Edit: here is a link to the 4 sided pit::http://www.readytocut.com/community/thr ... -pit.1041/
Enjoy
Mike
Enjoy
Mike
