It is currently Mon Feb 19, 2018 2:50 pm
New Rotary Axis Build
Mtw fdu
Postby Mtw fdu » Sat Nov 26, 2016 2:16 pm
Not sure if this is the right place but administrators please change if necessary.
After a long time thinking and working out how to do this I decided to go ahead and build a rotary axis. Here are some pics.
The first pic is the main plate with the necessary holes for bearing housings and it is mounted to my table at the end.
The next pic is the main plate with a bearing and housing in place.
Next pic is the back of the main plate with all hardware less an XL pulley and belt (waiting to arrive in the mail).
The last pic is my chuck mounted only on a shaft for demonstration purposes. I will be machining a piece of 100mm shaft down to 20mm most of it and also incorporating a backing plate for the chuck.
Need to acknowledge some of you guys for the help I have received.
Jester Thanks for the ideas and pics you sent. Now working with my cnc guy and everything is running now to plan...Cheers!
More pics to come soon.
I will be using my existing Y axis motor connected with a belt and XL pulley to the top shaft and this will be connected to the bottom shaft with a sprocket and chain.
Mtw fdu.
PS My table is only 600 x 600mm (cut table). My tube cutter will only allow up to 500mm length of tube. This is ok because I do not intend to do anything "big" on my table.
Camcutcnc 2 x 2 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Brand X
Re: New Rotary Axis Build
Postby Brand X » Sat Nov 26, 2016 10:54 pm
Good job, keep posting updates. Always interesting to watch a build of someones own design.. Good ideas come out of them for everybody.
Mtw fdu
Postby Mtw fdu » Sat Dec 03, 2016 1:24 am
Thanks for your comments Brand X.
Did some more to it and here are some pics.
The first pic is the piece of 100mm shaft material I used for the chuck backing plate and shaft combined.
The second is the shaft machined down to the 20mm I need.
The third is the chuck bolted to the new backing plate and shaft.
The fourth and final pic is the chuck mounted on the backing plate and installed on the bearings.
Should have the rotary axis running tomorrow. Will post more pics and a video of it turning without any cutting.
Mtw fdu.
Proma THC
Mtw fdu
Postby Mtw fdu » Sat Dec 03, 2016 5:06 am
1 thing I forgot to ask is how do you earth the rotary axis? Also how do you earth the material being cut? Thinking that the earth lead from the plasma machine will get wrapped up if continuously going round and round.
Thanks in advance.
Mtw fdu.
Proma THC
exapprentice
Postby exapprentice » Sat Dec 03, 2016 7:26 am
Hi Mtw fdu
Take a look at this video:
https://www.youtube.com/watch?v=d2fscbLNtGU
at about 0.44 seconds in will give you some ideas ;)
Best Regards to all
Exapprentice :D
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting :(
Postby acourtjester » Sat Dec 03, 2016 12:22 pm
I use a flat braided battery cable on mine.
Everlast PM 256 tig
Mtw fdu
Postby Mtw fdu » Sat Dec 03, 2016 4:13 pm
Thanks exapprentice and acourtjester.
Can you show me the other side of that pic you sent please acourtjester? Thanks in advance.
Mtw fdu.
Proma THC
Postby acourtjester » Sat Dec 03, 2016 8:53 pm
it is hard mounted to the frame so it is also hooked to the plasma return wire (work return wire).
The spring is used to hold tension on the flat braided cable in both directions of rotation.
Everlast PM 256 tig
Mtw fdu
Postby Mtw fdu » Sat Dec 03, 2016 9:26 pm
Thanks Jester.
Did some more and got it running. Here are more pics and a video.
https://www.youtube.com/watch?v=HxO4wG-w4J0
Mtw fdu.
Proma THC
Corfabrication
Postby Corfabrication » Thu Dec 08, 2016 10:09 pm
dang, that was some lathe time there.
_Ogre
Postby _Ogre » Fri Dec 09, 2016 12:38 pm
Mtw fdu wrote:1 thing I forgot to ask is how do you earth the rotary axis? Also how do you earth the material being cut? Thinking that the earth lead from the plasma machine will get wrapped up if continuously going round and round.
Thanks in advance.
Mtw fdu.
we use our table mostly with the rotary head for exhaust tubing
this is how i did our table similar to acourtjester, the other end is attached to a spring
as long as the chuck is tight there is no arcing on the internal parts of the chuck :mrgreen:
we have a ground lug welded to the water pan and work clamp
main ground to a buss bar that has all the earth grounds attached
Capstone
Postby Capstone » Fri Dec 09, 2016 1:12 pm
I'm curious if you've gotten far enough in the process to test backlash. It seems from the video that with the heavy chain and gear reduction there's an audible "ka-chunk" that sounds like slop. Hope that's not that case and we'd like to see cutting vids too.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
Mtw fdu
Postby Mtw fdu » Fri Dec 09, 2016 2:40 pm
Corfabrication. Yes that was a lot of machining which had to be done. I took my time with it so I didn't have to start with a new piece.
Ogre. Thanks for your info.
Capstone. That "ka-chunk" is backlash. I still need to make a tensioner for the chain. Have been waiting for my cnc guy with the next step of info he needs to finish my rotary "profile" so I can start cut testing parts. I needed to get as much as I have done so I could tell him what distance a full revolution of the chuck was. I tensioned the chain by hand while rotating with the jogging and it came up to be 50mm.
Will post more video and pics when I get to the next stage.
Thanks again guys.
Mtw fdu.
Proma THC
Postby acourtjester » Fri Dec 09, 2016 2:50 pm
I did not see any backlash with mine but I did use a smaller chain (#35)
https://www.youtube.com/watch?v=mDO9sx8NiPA
https://www.youtube.com/watch?v=rz7nVt1EvX0
Everlast PM 256 tig
Mtw fdu
Postby Mtw fdu » Thu Dec 22, 2016 3:43 pm
Still waiting to get my "profile" from my cnc guy. Can't do anything until I have this.
He is now starting to annoy me with false promises of sending it to me. :x :x :x
Mtw fdu.
Proma THC
Mtw fdu
Postby Mtw fdu » Mon Dec 26, 2016 8:07 pm
Jester...or anyone else that may know...
Somewhere in Mach 3 there is a chart to use to convert steps per mm/inches from flat plate to round tube. I cannot find it so can someone please point me in the right direction? Thanks in advance.
I am still having trouble with my cnc guy not sending me my profile so I need to do it this way.
Mtw fdu.
Proma THC
motoguy
Postby motoguy » Mon Dec 26, 2016 11:36 pm
Mtw fdu wrote:Jester...or anyone else that may know...
Mtw fdu.
Here:
https://www.machsupport.com/forum/index ... ic=16260.0
or here?
http://www.machsupport.com/forum/index. ... 315.0.html
Mtw fdu
Postby Mtw fdu » Tue Dec 27, 2016 1:59 am
Thanks motoguy.
This is what my cnc guy sent me about 2 months ago.
1) Switch the Y motor output pins to the A axis output pins
2) insert the Y motor tuning values into the A axis
3) Make sure that A is set as rotary
4) change the A steps per so that you get an acurate angular movement - IE
360 degrees = 1 rotation
Go to this website and download Gcode ripper
http://www.scorchworks.com/Gcoderipper/gcoderipper.html
make the gcode for your part in Bobcad
Open the Gcode in Gcode ripper
Convert to rotary
Is this another way of doing it as well?
Thanks.
Mtw fdu.
Proma THC
Postby acourtjester » Tue Dec 27, 2016 11:22 am
personally I go for the simple method I switched my X motor cable (X on my table) to the rotary stepper motor. Then ran the axis calibrations on the tube diameter I would be cutting with a paper taped around its diameter to calculate the distance moved by the X axis.
Remove the paper and cut the tube perfectly.
I’m no rocket scientist but I did work at the Kennedy Space Center many years ago. :lol: :lol:
Everlast PM 256 tig
tcaudle
Postby tcaudle » Tue Dec 27, 2016 1:02 pm
With an extra motor and driver and the Rotary XML, screens and POSTS the software does all of that for you . There is a calibration macro with screen inputs to get the correct ratio for the rotary axis. Then you just input in the Screen the pipe diameter and it does all of the calculations . Its all done in linear units and not degrees of rotation. You lets you draw the shapes in 2D and it (mathematically) wraps the 2D around the pipe for you
You can also look at the Rotary Plasma Plugin for SheetCAM. The way you do the rotary and drivers is up to you . It defines "A" as the defautl rotary but you can change it in the POST to be another axis. Having the extra motor and driver affords you the option to do square tube cutting too.
Mtw fdu
Postby Mtw fdu » Tue Dec 27, 2016 4:39 pm
Thanks guys for your input.
I decided to use my existing y motor axis to run my rotary because it was the cheapest and easiest way to go. I cannot get in touch with my cnc guy as he is not answering any emails or telephone messages so it looks I am going to have to wait until he decides to do the right thing and send my profile. That way he has done everything that needs to be done.
I just thought I could do the adjustments but it still seems complicated to me to tackle it.
I will keep you guys updated as I go.
Thanks again.
Mtw fdu.
Proma THC
Mtw fdu
Postby Mtw fdu » Wed Jan 04, 2017 4:43 am
Did a little bit more to my rotary axis.
Cut and installed a chain tensioner to the top and bottom shafts as well as mounted my earth cable (braided copper) to the chuck shaft for earthing it together.
Still have not yet heard from my cnc guy.
Mtw fdu.
Proma THC
Mtw fdu
Postby Mtw fdu » Tue Jan 10, 2017 7:11 pm
Finally...I got my profile from my cnc guy.
Will do all the change overs and setting the ports and pins and motor tuning over the next few days and will post up some results after testing. And some more video as well.
Mtw fdu.
Proma THC
Mtw fdu
Postby Mtw fdu » Wed Jan 11, 2017 5:50 am
Had some spare time to work on my rotary axis.
Have done everything to setup Mach 3 apart from how do I make sure A is set as rotary? Do I just make sure it turns when it is suppose to or is it more complicated than that. I am going by what my cnc guy sent me a few posts up (Number 3 on the list).
I will be testing tomorrow (Australian time).
Thanks in advance.
Mtw fdu.
Proma THC
Postby acourtjester » Wed Jan 11, 2017 10:41 am
Why not setup a separate Mach 3 profile for the rotary operation so when you want to use it you would just start that profile.
Any changes in steps or speed could be in the separate profile.
Everlast PM 256 tig
Users browsing this forum: No registered users and 5 guests
