Z axis lifter recommendation?
- Capstone
Re: Z axis lifter recommendation?
The only differences I see between yours, Gamble and mine is the mag-release, floating home switch, and the color. The ohmic sensor bit is unclear. The Magnetic release setup is definitely interesting.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
I had some bugs to work out with flashcut. But it was an issue with my table. Kept cutting alll goofy and after a few hours the backlash nut came off. After replacing it the table is cutting great.
The lifter still works very very well and have no complains. The magnetic breakaway has saved me a ton of money already.
The more I use the software the more I like it.
Having the cut charts built in is the best part. I select the material and thickness and it does the rest. If I had a PM65 it could control the amperage for me too.
I would buy it again no questions asked
