Font Id help please
Font Id help please
I can generally figure it out between whatdafont and dafont but I need some help with this one please.
- ben de lappe
Re: Font Id help please
For informational purposes only; it's not in the Torchmate CAD text compose module either.
- Larry83301
Closest one I can find is " Carnivalee Freakshow "
Thank you. I also found IFC Railroad, just not quite the same.
Ummmm.... Looks like you can just take a typical Arial font, trace up a few of the "jester crowns" on the top and bottom and do a copy, paste and get something reasonable enough to work with...... it's a little work, but if that's what you need you can make it happen.
That's it, I have that one from DafontLarry83301 wrote:Closest one I can find is " Carnivalee Freakshow "
also there was one with western in the title that was similar
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
- ou812
try saloonExt
- Larry83301
ou812 wrote:try saloonExt
Just trim off the extra bump in the middle and it would look the same, closer then the one I found.
Thank you guys I appreciate the help. I had a customer order the whole alphabet and I was trying to get away with being a llittle lazy. She actually ordered two of everything and extras of the more popular letters. I sure didn't want to turn that away it will just take a little time.
