Those of you running pen mounts on your plasma tables. Do you change your SheetCam post to add a tool much like a scribe where it will account for the offset of the pen from the torch center?
Or do you just manually set pen location and run the post?
Just setting one up and curious as to how others handle this situation.
Sharpie Pen Mount
- tnbndr
Sharpie Pen Mount
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- steel 35
Re: Sharpie Pen Mount
I pull my torch and use this, don't have a offset and do use a separate tool. Will find the post I learned from.
http://www.plasmaspider.com/download/fi ... &mode=view
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- steel 35
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
I take my scribe out. I wrap tape around my sharpie to about the diameter of the scribe. Mount it in scribe mount turn down pressure to about 10 psi and scribe pressure to zero. Works good so far.
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
I made a adapter for a standard ink pen and mount in the torch holder. I did set up a tool for SheetCam that is for the pen only.
- tnbndr
I ended up with a mount made for me by acourtjester, although the pen hits the torch holder unless I move it way down. After some playing and help from Dan at LDR I got it all working. Had to set up two profiles of SheetCAM. Dan was going to send me his version of the pen holder but he must have got swamped and it never arrived. I got what I needed done for now but need to revisit the pen holder when I get time.
Man, I feel trashy with this pen mount
LDR 4x8 w scribe
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
- tnbndr
Hey, whatever works.!!!!Man, I feel trashy with this pen mount
Good looking setup ..i just printed one of the many available on thingiverse ..The one i use has a slit in it so it never clamps tight on the pen ..It uses a rubber band to put down pressure on the pen and acts as a floating head so the pen can follow uneven surfaceacourtjester wrote:I made a adapter for a standard ink pen and mount in the torch holder. I did set up a tool for SheetCam that is for the pen only.
That is why I used the spring in mine.
have fun
tom
have fun
tom
