Cut ready alphabet
Cut ready alphabet
I had to upgrade to a new computer and I lost the file for the CNC alphabet that was posted a couple of years back. Would anyone have the link for this?
Thank you
Thank you
Re: Cut ready alphabet
Hi
i think have it i'll check tomrrow and if i i'll be happy to post
thermal dyn 152
4 x 8 eagle plasma table
400 amp portable welder
250 amp Lincoln stick
miller cp300 w/ S-52d
miller cp300 w/S54a setup for alum
13 x 60 south bend lathe
emco mill
Amer bender
http://www.facebook.com/gene'sweldingandfabrication
emco mill
Amer bender
Thank you for your help
yes I could use it myself
Hi. Found these in the search box. Not sure if they're the ones you need.
http://plasmaspider.com/download/file.php?id=23716
http://plasmaspider.com/download/file.php?id=35992
New to the page but everytime I try to download something and in this case all the alphabet letter it always has a bunch of numbers and words on left hand side of screen when I open downloads ... Is there something I need to be doing different ?
FATHER & SON'S WELDING & METAL ART S.C.
- Larry83301
What are you "opening" them in? Some programs need to have them improted into. All of the files in this post open great in MasterCam.swtodd1 wrote:New to the page but everytime I try to download something and in this case all the alphabet letter it always has a bunch of numbers and words on left hand side of screen when I open downloads ... Is there something I need to be doing different ?
What about truetype or PS fonts? are there tested fonts in those formats that are ready to cut? Also, is there a term that is useful for finding fonts on font sites when searching? Like "fonts with supports"? Typically "stencil" is a useful keyword. But I find most of those to be strongly styled as stencils as opposed to artistically created to look like average fonts but have supports so they can be used as stencils.
try www.dafont.com
Omax 80X Waterjet 6 x 12 with Tilt-A-Jet
CamFive 150w Co2 Laser
Miller Mig & Tig
Whitney-Jenson 20 ton Punch Press
Atlas Lathe
Miller Mig & Tig
Atlas Lathe
look up software called stencil font it cost about $30 but they say they convert any true type fonts to stencil fonts.
download for free and check it out
Thanks for the recommendation. I checked out the software and it outputs to dxf or g-code. I'd really like it to output a new truetype or ps font, so I sent the author a note with the recommendation. I'd prefer to have the font include the aperture so I can work with it directly in illustrator and not have to go through a conversion each time or deal with dxf letters to move around and adjust.
I did a search and it came up with about 40 different ones ???Do you have a link for the one you are using?acourtjester wrote:look up software called stencil font it cost about $30 but they say they convert any true type fonts to stencil fonts.
I have not bought the program as I use inkscape and convert the letters I use but here is the web page for the program
They have 2 one is just stencils of any ttf the other seems to deal with DFX and G-code
http://www.cadkas.com/stencil-fonts.php
have fun
Tom
have fun
Tom
Thanks i will check it out..I do the same thing as you just modify them in inkscape ..But it would be nice for guys who do alot of signs and stuff like that to have this program..
Might want to get a free copy of DeskEngrave. It can take fonts and create Gcode or DXFs for you. Than way you have almost any font you can find right at your fingertip. Pick the font set teh scale type in the words( straight or curved) and save to file.
It works very well here, (;-) TP
