Nice, will keep an eye out for one, does look very useful.Brand X wrote:I use this... SH-100A .Spendy as heck, but great air tools. e-bay is your friend here. keep looking until one shows up..SeanP wrote:Looks spot on Dave! Well done.
What do you find best for edge clean up inside the intricate bits?
Cheers
http://www.nittokohki.com/tools/product ... /airfiles/
Building a new table, any tips?...
Re: Building a new table, any tips?...
- SeanP
Thanks Dave, someone called yesterday looking for some internal lettering from stainless, should be ok once I get the 30a parts.
I wasn't sure if he needed 304 or 306, do you think 304 would be ok for outside 15m inland from sea?
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- SeanP
I did these yesterday from 3mm, they turned out well.
https://goo.gl/photos/U6rcs7MzJmcPpwZu5
Powermax XP45
Table build gallery
Table build gallery
15 miles or 15meters ?
I couldn't really recommend a grade, it wasn't until i had made and sold three plaques for outdoor use that i realised i was using a grade of SS that rusted 316 I think it was, much cheaper than 304.
As for the air file - something like this???
http://www.ebay.co.uk/itm/Sealey-Air-Sa ... SwFnFV8FVX
Those letters look very sharp, niceSeanP wrote:I did these yesterday from 3mm, they turned out well.
Are the studs Tig welded on??
- SeanP
Ya miles
Sorry I got that wrong meant 316, that is the better grade 'I think' I'd better do some googling
Powermax XP45
Table build gallery
Table build gallery
- SeanP
Thanks, just been for new glasses todaydavek0974 wrote:Those letters look very sharp, niceSeanP wrote:I did these yesterday from 3mm, they turned out well.
The locating hole just into the surface worked great.
Powermax XP45
Table build gallery
Table build gallery
I have one of those, but Nitto also. I think the file is best, but looks like the flat blade would work on some minor work (Soft material) Unless that file supports a round shank type of file where it installs in the holder..davek0974 wrote:
http://www.nittokohki.com/tools/product ... index.html
My mistake, it was grade 430 that was poor, 316 would indeed be ok for use near sea etc
- exapprentice
Hi Sean
definitely 316 don't use anything else it is the most expensive option, but trust me, from experience 304 etc will show rust spots over time
I did a whole set of railings and the customer wanted to reduce the cost of St/St and spec'd 304, then tried to blame me for using the wrong st/steel
soon sorted that one out.
316 is far better, welds better as well
regards
exapprentice
regards
exapprentice
Best Regards to all
Exapprentice
(Pete)
Exapprentice
(Pete)
- SeanP
Thanks for the info, 316 it is then, cheers.
exapprentice wrote:Hi Sean
regards
exapprentice
Powermax XP45
Table build gallery
Table build gallery
- exapprentice
Hi Sean
just noticed in one your pictures looks like your using a # SR-26 TIG Torch, Have you tried using a SR-17 for the smaller stuff
just wondering as I use the 17 nearly all the time with steel & st/steel
regards
exapprentice
regards
exapprentice
Best Regards to all
Exapprentice
(Pete)
Exapprentice
(Pete)
I generally use a #9, and 20 water cooled torch.. If you want to keep the #17 /#26 size, then get some of these. I put them on my 17 series torch.. helps for gas coverage, and also uses less gas too.. you don't have to buy the whole kit either, Just the size you use..
http://www.usaweld.com/Stubby-Gas-Lens- ... 1stglc.htm
- SeanP
No just been using the torch I got with the machine to be honest, I'm not that long getting back into tig, I'll look into that thanks, gas lens was something I need to get as well.exapprentice wrote:Hi Sean
regards
exapprentice
Thanks BrandX as well, that's me going to make the order now, cheers
Powermax XP45
Table build gallery
Table build gallery
- exapprentice
Hi Sean
just wondering how you sharpen your tungsten's
we could start A whole new post on TIG welding and how we could help each other based on the amount of knowledge out there
just thought I would ask
regards to all
exapprentice
regards to all
exapprentice
Best Regards to all
Exapprentice
(Pete)
Exapprentice
(Pete)
- SeanP
Might get slated but,,,,,,battery drill and grinder/sanding disc it works ok for me.exapprentice wrote:Hi Sean
Powermax XP45
Table build gallery
Table build gallery
