The Baileigh $1,000 Giveaway / Contest
waters035
Re: The Baileigh $1,000 Giveaway / Contest
Post by waters035 »
Here is another project I made this month. Its a 48 charcoal BBQ with prep shelf. It was designed with tabs on the ends of the plates so everything just fit together like a puzzle. Main frame is 3/16 plate with 16ga lid.
waters035
Post by waters035 »
Made this custom truck bed for my brother in-laws 1974 Chevy C10 step side.
waters035
Post by waters035 »
Made a few of these as well. The body is plasma cut from 7" tube on our tube attachment. Then the ends and grill were cut from 3/16 plate. They turned out very nice.
SeanP
Weathervane
Post by SeanP »
This is my entry to the Baileigh contest, it's something I have been planning and wanting to get into for a while now, just worked out at the right time for a entry here.
I started out on this plasma cutting adventure 18 months ago now,,,,,youtube has a lot to answer for! that's where I first got the idea to build a CNC Plasma table.
The help I have had from people on this and other forums has been amazing, one person in particular (AJ from Baton Rouge) he is half way around the world from me , almost on a daily basis we exchange emails discussing problems and jobs.
Pics of my table building adventure LINK HERE
So here is a video showing the production of the 'Weathervanes' and some of the designs LINK HERE
Video of working Weathervane LINK HERE
And the photo album of the project LINK HERE
Many thanks
Sean
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
DARRYL21270
Post by DARRYL21270 »
Here's one we just finished up tonight. We wanted to do an ocean theme so we cut some coral and added stone and a giant sea turtle. We still need to powdercoat the turtle but for the most part it's all finished. The two large curved pieces you see are actually and old piece of railroad track that we cut in half using an oxy/acetylene torch and the heat from the torch gave us the bends you see. Each piece was hand drawn and cut separately on our 4'x4' Tracker CNC Plasma Table, cleaned then powdercoated and welded in place. The turtle was the most challenging with over 100 lead ins and took the most time to complete. The entire piece stands about 6' tall and 4' wide I hope you like it.
I've also attached a few of our original sketches for you to see.
m79b01
Post by m79b01 »
Well here is our entry. I was hoping to have the website up and have them on the market, but.....
Then add the sides. Either in diamond plate or smooth for decals or paint.
And the point of all this........
Hopefully we can give some added functionality/mobility for our veterans and disabled.
Thank you for the opportunity to share.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
M & N Steel CNC
Post by M & N Steel CNC »
Thanks to all the folks at Baileigh for this awesome opportunity to view others creations and art. And for making a great product!!
In 2011 my husband and I got a crazy idea that we wanted to cut metal art and signs, well mostly me, he went along for the ride. I was thinking this would be a great retirement opportunity for him. We purchased a Plasma Route made right here in Ada Oklahoma. I knew absolutely nothing about how to do this or what I was getting into. I just knew I wanted to do it.
Thanks to this site, we have become very successful, and enjoy it very much.
My entry is a light we made for our patio. We love the outdoors and enjoy watching the deer and hawks that spend time in the area. This light is made from 14 gauge steel and is 6 separate pieces. The Letter ' R ' in the end is the initial of our last name.
First is drawing the design in Corel Draw X5. I had the vision of a pool table style light. Drew the frame for the front. Then the frame for the end. When you rotate the end to the side in your drawing they should match so you know they will fit when welded.
Make a contour of the front piece to give a frame and combine.
Now for the design, find drawings of what you want to see in the inside and trace or use pre-made DXF files.
Combine together to give you the look you are wanting. Delete all small openings or holes, looks better without them. Lesson learned, this is a plasma design not laser, cutouts too small are bad, take them out. Combine all the individual pieces to form your design.
Make a DXF of your final project, one end, one side and one top. Need to cut 2 ends and 2 sides, and 1 top.
Insert file into sheetcam, select metal and tooling, sheetcam makes cut paths with lead ins and leadouts. Then create the G-code in sheet cam.
Insert file into Mach 3,
Now the fun begins. Decide on a place on your sheet of 14 ga that you want to cut the design out of, move the torch to that point and reset your x and y. Make sure your piece in grounded, make sure your piece is grounded, make sure your piece is grounded, yes, I have made this mistake more than once:) Select your THC on, then press RUN. Watch for pieces that don't fall thru and stick up, don't want your torch to hit them and move the steel, pick those up with a magnet.
When the cut is finished, now you can breath again.:]
Remove dross, Match pieces for fit and weld up, Prime and paint.
Painted with Moonlight copper metallic paint, Love the finish.
Attach light bar, hook up electrical and make sure it all works.
Hung up to show off our fireplace and give ambience to our patio.
See second post for final pictures.
Hope you enjoy our design and work. Love your products.
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
M & N Steel CNC
Placed colored plexi glass on inside walls to give warm glow.
Thanks again for giving us the opportunity to view the creations of others.
Nancy and Mike Regan.
Last edited by M & N Steel CNC on Sun Jun 01, 2014 1:04 pm, edited 1 time in total.
Corel Draw X5
SheetCam
Oldsarge
Post by Oldsarge »
Here's my entry for the Baileigh contest.
I became interested in Plasma cutting a few years ago. I built my own table after studying other builds, brands and features. You can look at my build thread here: http://www.plasmaspider.com/viewtopic.php?t=7444 There's lots of links to videos I made at the time, and I asked and answered tons of questions. I couldn't have done it without Plasma Spider and all the awesome folks who are a part of this community!
So the first link is to the overview video of my submission... it's around 11 minutes, sorry, I tried to keep it short while including everything. The second link is to a sort of instructional video of me fabricating the bulb cage. It's around 8 minutes. Again, I apologize for the length... I just taught myself some basic video editing to be able to do these submissions.... I'll get better at it!
I'd like to thank the folks at Baileigh for sponsoring the contest. It really motivated me to take my work to another level which I always strive to do, but knowing that there's a possibility to own a piece or two of high quality metal working tools from Baileigh really inspired me! I hope you like my work... It was a mixture of fun, frustration, problem solving and a lot of hours in the shop after working on other projects during the day.
So without further ado, I present "Kansas" my entry to the Baileigh Giveaway/Contest.
https://www.youtube.com/watch?v=94iyBGdaqIM
https://www.youtube.com/watch?v=A_8_Axw14LI
Thanks for looking, and I hope you like my project.... I've really enjoyed working on it, and I'm so very thankful for all the assistance and knowledge I've gained here over the last few years!
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
muzza
Post by muzza »
Thanks and congratulations to all that entered, one one may get the prize but you are all in winners in your own rite. Some great submissions and thanks to Baileigh for running the contest.
Murray
wilber
Post by wilber »
muzza wrote:Thanks and congratulations to all that entered, one one may get the prize but you are all in winners in your own rite. Some great submissions and thanks to Baileigh for running the contest.
Murray
I agree, they all look great.
yeomansjon
Post by yeomansjon »
First of all, I just want to say nice job to everyone that has submitted their contest entry, they are all very impressive! Nice to see the wide range of talent on the site.
This is my second entry and really was something that I have always wanted to work on but never had a reason to sneak it to the top of my priority list. I made a custom Headache Rack for my truck. I worked on the Aluminum sign that I posted earlier in this contest toward the beginning of the month but as soon as I finished that I jumped on this as my 'fun' project.Having broken a few back windows, this is long overdue. I never really found a headache rack that I liked that you could buy at the store so I made my own. And I'm pretty sure it turned out such that I can pick up the whole truck just from the rack.
I made this out of 11ga 1.5x3" rectangular tubing, and custom plasma cut 11ga sheet metal by yours truly. The mounting feet that attach the rack to the truck bed was plasma cut rectangular pieces of 3/8 plate. I took some rough dimensions and roughed out an outline in Autocad. Then after playing around with how I wanted it to look I finally came up with a design that I was happy with. I then used Autocad to give me the cut dimensions I needed for dicing up the square tubing that I bought in 10' lengths. I did all this with a 'wobbly' chop saw which introduced a few issues but other than that all the pieces fit perfect. I Mig welded the steel frame together. Then I plasma cut some 3/8 plate into mounting plates and welded those to the frame.
Once the frame was assembled, I set it up on the truck to verify that it had the look I was going for and that it fit correctly. At this point I really got excited because it started to feel 'real'. I plasma cut some plate with oval cutouts for LED stop/turn/tail lights, and LED backup/spot lights. I plasma cut a plate for mounting a 120 VAC outdoor electrical box since I have a power inverter hard wired through the truck. I also cut a second electrical box plate with a rectangular hole where I plug in my PA speakers for listening to music while camping or tailgating. Then I also plasma cut some spider webbed corners to strengthen the feet to the frame though I'm not sure it really needed (but that's my story and I'm sticking to it). I was going to cut 'Mudflap Girls' instead of the webs but the ole' lady thought the webs looked better...
I plasma cut my business and website into some plate that I screwed into the frame via tapped machine screw holes. I also plasma cut the Baileigh Logo as it only seemed fitting to put their name on full display for graciously offering up this contest prize! As you can see in the pictures, I coated those in some Steel FX Copper Patina and put a clear coat finish over the top for protection. I drilled and tapped holes for mounting so that during the different seasons I can put a different custom plate across the headache rack. I need to put some plasma cut Arctic Cat art work up in the winter! I can promise you, I will make this the most versatile headache rack out there.
I didn't want any of my wiring for the lights showing so I had to strategically drill holes in the square tubing so I could run all the wiring through the tubing to go down into the bed of the truck to mate with the Ford Wiring Harness. I had some electrical issues which caused the delay in the nice daytime pictures so I apologize if they are too dark. What's not shown is that I filled all the electrical pass through holes through the square tubing with rubber grommets as those hole edges were very sharp.
The final coat was a gloss black finish. After I drive around for awhile and use it and tweak it here and there the plan will be to powder coat it like I do with all my plasma cut finished products that are not Steel FX Patina'd. I will also run some square tubing down the length of the bed rails standing about 2" high with round posts along the way so I can tie equipment down easier and give the headache rack an even bigger 'look and feel'. I made sure to plan the height of the lower cross piece to be the right height to mate with it.
Hope you guys like what I did and if you have any questions, feel free to ask. I will also post the cad files of the pieces I cut on the dxf sharing side once I get all my corrected files of the Pcam computer. And I'd be happy to share the cad file for the frame design if anyone cares.
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
Baileigh Inc
Post by Baileigh Inc »
Wow, we had a ton of last minute entries. Give us a little while to review.....
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
Baileigh Inc
OK, wheeew! This was a close one!
After much debate......the winner is M & N Steel CNC
We would like to thank everyone who entered
Shane Henderson
Baileigh Industrial
920-482-3220
M & N Steel CNC
WOW!! :mrgreen:
Thanks so much Baileigh!!
Corel Draw X5
SheetCam
Baileigh Inc
M & N Steel CNC wrote:WOW!! :mrgreen:
Call me 920-482-3220
Shane Henderson
Baileigh Industrial
920-482-3220
SeanP
Post by SeanP »
Well done M & N!
Powermax XP45
Table build gallery
M & N Steel CNC
SeanP wrote:Well done M & N!
Loved yours also Sean P!!
Corel Draw X5
SheetCam
Oldsarge
Post by Oldsarge »
Good On Ya M&N ! The lamp is very well suited in that location!
Oldsarge
M & N Steel CNC
Oldsarge wrote:Good On Ya M&N ! The lamp is very well suited in that location!
Oldsarge
Thanks Old Sarge, Loved your Kansas Steam tornado, Just like home!
Corel Draw X5
SheetCam
m79b01
Post by m79b01 »
Well done all and congrats M&N. Keep up the good work everyone.
Thank you Baileigh for the opportunity to participate!
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
Nacs Fab
Post by Nacs Fab »
Congrats on the Win! Thanks for the giveaway Shane and the Baileigh Crew!
G540 with LCTHC by candcnc
all built... by me...
waters035
Post by waters035 »
Congrats M & N Steel CNC. Where do you get the coloured plexi ? Is is less expensive than mica?
Jason
M & N Steel CNC
waters035 wrote:Congrats M & N Steel CNC. Where do you get the coloured plexi ? Is is less expensive than mica?
Jason
Jason, our local Glass and window store had some that he has had for a long time and gave me a good deal on it.
Corel Draw X5
SheetCam
Craig
Post by Craig »
Congrats Nancy & Mike, beautiful light, all where good entries, must have been a tough deciding on just one. Craig Johnson
Craig Johnson
