It is currently Sat May 26, 2018 1:55 pm
Grounding the CNC table?
anarc
Postby anarc » Fri Apr 20, 2018 5:45 am
Hello plasmaniacs,
I am a bit confused about grounding the CNC table.
All those things I read just confuse me more :-(
Most threads talk about putting the ground clamp to the material.
But in fact the clamp to the material is (+) , not ground.
So why is everybody speaking about ground?
If I use the plasma torch manually there is just the + clamp and the - torch and the grounding of the inverter of course which is grounded through the power grid.
So I assume the grounding is just to protect the CNC electronic from potential peaks? Not for my personal safety?
Currently my water tub is not connected to the table, nor is the torch as it got a plastic handle. The rest of the table including the motors housing are connected.
I read it is useful to ground the portal and the z-axis but for what scenario?
thanks
anarc
WyoGreen
Re: Grounding the CNC table?
Postby WyoGreen » Fri Apr 20, 2018 11:38 am
Good grounding practice is to connect the frame of the table to a separate ground rod located close to the table. The reason for this is cut down on noise generated by the plasma arc from affecting the motor and data cables on the table.
You are correct that the plasma machine clamp is not ground. It is the return path for the current from the plasma torch. Best practice on that is to connect it to the material being cut to ensure a good return path to the plasma cutter.
CNC Router table
Postby tnbndr » Fri Apr 20, 2018 11:47 am
You are correct the plasma clamp is not a ground but the +. People think of it like a welder so call it ground or negative. Most of us understand so don't correct. But that + clamp should be directly to the material you are cutting, not just the table or slats.
PM45
Miller 211
RW 390E Slip Roll
Postby acourtjester » Fri Apr 20, 2018 1:05 pm
On the plasma unit it is call a work lead, This helps to keep the polarity clear.
As with many electrical things you have a circuit and the more connections in a circuit the more problems.
Attaching the work lead to the metal being cut gives you the best path for the plasma circuit, going through slats and table frame just adds to the number of connection. The arc OK is a check of the current path for the Plasma circuit, no path no cut.
Everlast PM 256 tig
anarc
Postby anarc » Fri Apr 20, 2018 1:29 pm
Thanks for the replies. Yes, I read about the rod in the ground but I have no idea how I´d get a 8' rod of copper into the ground. I could split computer and plasma using different phases but the ground would still be the same so that is probably not a good idea either. Any good guess to get around the grounding using the rod?
Postby djreiswig » Fri Apr 20, 2018 1:33 pm
I don't have anything grounded on my table other than the power connections and I have had no issues with noise, so I'm not convinced it's all that necessary. JMO.
anarc
Postby anarc » Fri Apr 20, 2018 1:35 pm
So you grounded the table on the power grid ground or not even that ?
Postby djreiswig » Fri Apr 20, 2018 1:39 pm
Plug the plasma in to a 220 cord with a ground wire, and the controller into a 110 cord with a ground wire. That's it.
Postby jimcolt » Fri Apr 20, 2018 2:10 pm
The cable that goes from the plasma cutter to the cutting slat bed is called the "work cable" by Hypertherm and other plasma cutter manufacturers, has never been called a ground cable. If you are not having any electrical noise related issues and are using an air plasma cutter with blowback start technology (all Hypertherm Powermax systems), then there generally is no need for an earth grounding rod. If you determine you need an earth ground rod it should be installed as follows: 1. Driven about 8' into the ground right next to the cnc table for best effectiveness. 2.Run the work cable from the plasma cutter directly to the ground rod, do not use the clamp, rather the cable should be bolted to the rod. The cable also must be cut to the exact length it takes to get to the rod, so shorten it and do not coil. 3. A short length of the same type and size of multi stranded (do not use less strands or single strand....as RF electrical noise travels on the outside of conductors and most efficiently gets to earth on multistrand cables) should be connected from the ground rod to the slat bed frame (bolted to clean, unpainted metal). If you desire a cable with a clamp as well, connect it (bolted) with the other cables from the ground rod....and leave just enough length with a clamp on the end to clamp to your plate. (note, I have been plasma cutting in my home shop for over 20 years....never once had an issue that required I clamp the work cable to the material) While on the subject...another help for electrical noise related issues on a shop cnc machines is to get a good quality UPS (uninterruptible power supply) as used for office equipment. Plug the 120 volt for your computer and the 120 volt for your drive electronics into the filtered, protected outlets on the UPS. Make sure the UPS is sized for the combined Wattage for the electronics and computer x 1.5. Jim Colt Hypertherm
anarc
Postby anarc » Fri Apr 20, 2018 3:28 pm
Thanks for the detailed answers! Very helpful.
