It is currently Wed May 23, 2018 6:32 pm
Getting close to the finish
Postby acourtjester » Sat Jun 10, 2017 4:20 pm
I am getting close to the finish of table #7, this is a scratch built DIY table. It is a 4X8 table base with both router and plasma torch mounts.
I have powered it up and did the steps calibrations home and limit switches are installed and wired. Attached are a few images.
Everlast PM 256 tig
little blue choo
Re: Getting close to the finish
Postby little blue choo » Sun Jun 11, 2017 12:29 am
Looking Good
Rick
Rick
Arclight 9600 4x8 table
Nacs Fab
Postby Nacs Fab » Mon Jun 12, 2017 11:37 am
Nice work as always. EDIT: sorry I see the carriages in the first pic. Again nice work!
G540 with LCTHC by candcnc
all built... by me...
Postby acourtjester » Tue Jun 13, 2017 8:59 pm
First router cuts with my new table, Plasma will be next. :D
https://www.youtube.com/watch?v=X_i9ZzEp6PU
Everlast PM 256 tig
ovrrdrive
Postby ovrrdrive » Wed Jun 14, 2017 9:21 am
Always makes me think of terminator when I see a machine making parts for itself... lol
Looking good.
Largemouthlou
Postby Largemouthlou » Thu Jun 15, 2017 5:35 am
Very nice!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
Postby acourtjester » Sun Jun 18, 2017 12:44 pm
Testing dust shoe when routing wood and aluminum, video shows it in action (turn down the sound). Removed 100% of the wood and 99% of aluminum.
I used 2 different bits, "V" on wood and 1/8" ball nose on aluminum. Not pleased with the ball nose :( I think the aluminum was sticking to it, will try a engraving bit soon.
https://www.youtube.com/watch?v=Rqg5sLQ4Y2w
Everlast PM 256 tig
Postby tcaudle » Sun Jun 18, 2017 2:23 pm
Use flat end milling tool two flute up cut spiral for routing aluminum . Mist or flood coolant Ball end does not clear chip. V bit works on AL for simple signage.
Postby acourtjester » Sun Jun 18, 2017 5:04 pm
thanks I will check into other bits
Everlast PM 256 tig
little blue choo
Postby little blue choo » Sun Jun 18, 2017 7:25 pm
Looking Awesome Tom!
Rick
Rick
Postby acourtjester » Tue Jun 20, 2017 4:47 pm
Little more progress, attached a Drag Knife to the Z axis plate and cut some decals for the controller.
Also completed the Floating Head assembly. :D
Everlast PM 256 tig
Postby acourtjester » Thu Jun 29, 2017 8:32 pm
Making some test cuts today with the router, I want to try custom Dovetails so I drew the 2 parts. Very happy with the first cuts I used a scrape to route them out and did a test fit. The orientation was not the way they would be for making joint but showed they will fit. :D
They ended up very tight need to adjust the finish allowance for a better fit. :lol:
Everlast PM 256 tig
