- mosquito weather vane.jpg (81.64 KiB) Viewed 4847 times
Weather Vanes
- tnbndr
Re: Weather Vanes
Nice job. Are you using bearings or just rod over rod to rotate the Vane section? What size rods do you use?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Weather Vanes
The top is just a rod (3/8") the part that spins is just a sleeve that is drilled out slightly larger to accommodate the powder coat on the rod, it is about 4" long, with 2 ball bearings staked on top. The directional cross does not spin. The base is another sleeve of the same tubing that is drilled and taped on the side to accept a screw to lock it down.tnbndr wrote:Nice job. Are you using bearings or just rod over rod to rotate the Vane section? What size rods do you use?
- Loyd
Re: Weather Vanes
Those are nice. How much do you sell them for?
Loyd
Loyd
Re: Weather Vanes
Having a bit of a run on weather vanes too at the moment. sold one last week and an another 3 this week.
this is the one I had on display (arrows ends look familiar ,thanks Jason at Cascade/ Free DXF)
but the customer wanted more detail on the rooster so I made this one (last weeks sale)
Now this week have to make one with a pointer, one with a mallard duck and one with a trout.
Selling so many I must be too cheap at $225, (the guy about 60 feet down the line sells his Chinese ones for $49) , mine run sintered bronze bushes on 12mm (a bit over 7/16) shafts and an 11mm bearing ball with adjustable base, Jet Hot ceramic coated shaft to carry bushes and powder coated finish , arrow is 750mm end to end (approx 2'6").
- tnbndr
Re: Weather Vanes
@muzza:
Nice, and yes I would say you are too cheap. These are custom made. Do a google search and look at the prices on the full body copper custom weathervanes. I have only made one weathervane so far and I donated to a club. But if I were to have charged for it, I would have asked $350.
When you guys say ball bearings, are you just setting a ball bearing on top of the lower shaft and the pushing the top part on over it? Not sure what sintered bronze bushes are, can you post a pic or link where you purchase?
Re: Weather Vanes
We actually sell ours for $135. People just don't want to pay big bucks for things anymore.
Re: Weather Vanes
muzza wrote:Having a bit of a run on weather vanes too at the moment. sold one last week and an another 3 this week.
Re: Weather Vanes
Here is a pic with the top or turning wind direction indicator part of the vane removedtnbndr wrote:@muzza:
In the bottom of the pic is the tube which the compass is welded to, this is adjusted to true direction and locked with a bolt. Next is the lower sintered bronze bush (part no SBC121820) 12mm IDx 18mm OD x 20mm long, then there is a spacer tube 65mm long and another bush which continues about 5mm further than the shaft to also act as a keeper for the 11mm bearing ball at the top.
The top part of the vane has the same 12mm shaft coming down from the arrow which has a 18mm ID tube 125mm long welded to it via a spacer. The bottom of the top shaft rides on the bearing ball and the outer tube runs on the bushes keeping everything rotating very smooth and will adjust in the slightest breeze. As Jet Hot do my powder coating I get them to use their high temp ceramic coating on the main shaft to protect it, normally I'd just zinc coat it but there isn't a plater nearby.
I have also had 1 customer insist on roller bearings in place of the bushes, by using these sizings I was able to get 2 bearings and just make another spacer tube at the top to house the bearing ball.
Sorry these measurements are in metric but it is all built from metric material, for conversion 25.4mm = 1inch
Hope this helps
Murray
Re: Weather Vanes
How do you know how to make the roof line plate with out the customer knowing the roof pitch?
Re: Weather Vanes
We produce a generic one. We haven't had any complaints. Lots of people also put them on posts so we make a flat holder as well.
