It is currently Tue Sep 25, 2018 1:19 pm
BBQ Grill - Non Welded
RAD
Postby RAD » Mon Jul 30, 2018 9:04 am
Hi folks, thought I would share my bbq pit grill. (not the file sorry!)
It's made from 3/32" (2.4mm) thick steel, just under 10 gauge and was bent by hand and permanently assembled without welding, did not have equipment like press brake and welder so I had to innovate. its rigid and held up well to the heat when grilling but only used it once though.
It has some nice features like adjustable air dampers, clean-out hatch for charcoal ashes and carry handles. Would like to do one with a cover but would cost almost double. Grilling area is approx. 12" x 22" and overall height is 11" it has a 4" clearance from underside the pit to the table top.
This is my first time building a bbq pit and welcome your comments on how I can maybe improve, would also be glad to answer any questions, TIA.
Re: BBQ Grill - Non Welded
Postby acourtjester » Mon Jul 30, 2018 11:05 am
Looks like a well thought out design Thanks for the share only suggestion would be a stainless steel grill plate.
Everlast PM 256 tig
JohnnyC
Postby JohnnyC » Tue Jul 31, 2018 10:31 pm
Nice!
levesquea
Postby levesquea » Tue Aug 07, 2018 10:26 am
Great design , simple, clean lines.
Plasmacam 4x4
Hypertherm Powermax 45
CorelDraw 2018
Inkscape
Aspire 9.0
Fusion 360
levesquea
Postby levesquea » Tue Aug 07, 2018 10:31 am
What software did you use to design the tabs and precise fit? or did you use paper templates?
Very well thought out.
Plasmacam 4x4
CorelDraw 2018
Inkscape
Aspire 9.0
Fusion 360
RAD
Postby RAD » Fri Aug 10, 2018 3:03 pm
Thanks, no paper templates other than the cardboard template I used to get the bends at the correct angles. It was designed it in AutoCAD, the slits to receive the two ends was a bit tight but a quick pass with a 1/16" cutting disc did the trick, other than that everything went together well.
Users browsing this forum: No registered users and 6 guests
