Store Front Sign
- csplazma1
Store Front Sign
Our first outside sign completed. .125 aluminum with 1.5 inch offsets using aluminum studs treaded with stainless nuts. 60"x30"
C&S PlaZma Metal Works
LDR Motion Systems 4X8 Water Bladder
Hypertherm Powermax 85 Machine Torch
Everlast PowerPlasma 60 Handheld Torch
Thunder Laser NOVA 51
Re: Store Front Sign
Congrats, that's a great looking sign.
Nice job. Those stand offs look tedious.
I have a question. I have done a couple of stand off plaques and signs. How do you keep your spacing correct on the standoffs and making sure the holes on the back plate are correct??? Always a time consuming process. Thanks Great sign. Looks good.
How I do it is to place the front part to the back part in their locations drill through both for the mounting studs. the mount the studs to the back part and position the front parts where you want them and plug weld the studs from the front side of the front parts, remove and finish them with paint or power coat before final assembly.
That looks awesome.
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
