Parts Bin Storage Rack - Harborfreight Bins
- Capstone
So I've seen dozen of videos of these stacked parts bins that people are suddenly getting organized with.
Most of these are made from wood, but that's not how we roll here.
I had a coupon from Harbor Freight for the medium size ones @ $7each, so I jumped on the limit of 7 per day... three times. I've got two more to make. I will probably narrow it up a bit so there's more surface for the bin to slide on, and to make it a little more snug, but the design itself wouldn't change, just the frame dimensions.
Using 14ga HRS, I came up with a design that stacks 7 at a time. The bending was tricky. I had to make a special break-die for it and the pressbrake will still deform the outer sides unless you own a super trick CNC pressbrake with a huge throat. I used square tube for the frame; 1/2 for the uprights, which straightened up the sides just fine once welded and 3/4 in square tube for top and bottom of the frame. I also included the .svg design if anyone wants to jump right in. You could easily add sides to close it in, to keep dust out or add your personal touch, but that will of course also add to the weight if you decide to hang it on the wall.
EDIT: I've updated the design to sharpen the corners and to move the shelves down in order to make sure the top bin clears the top frame. The first one I made I noticed that the corners were snagging on the bottoms a bit at the back.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: Parts Bin Storage Rack - Harborfreight Bins
very nice cool i can sure use one of them ..when some one convert it to a dxf
- steel 35
I drew that in my head but found a old bread rack that kept me from doing the bends thank's for sharing.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
this should work
Thanks Phil, great idea.
Keep it simple is always best, roller draw slides are great until they're not so great
Murray
Murray
- rons
neet idea
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Lathe, BP, 1" x 12" Cosan Miter Saw,
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
- otisa2007
great idea thanks
- little blue choo
Thanks for the share Capstone. Good to see functional ideas, not just artsy stuff.
Rick
Rick
Rick
Arclight 9600 4x8 table
Man that is so simple why did I think of that years ago I going to cut this asp I have a stack of 10 of them on top of each other and every time I need something out of one it on the bottom
- Capstone
Happy to hear that folks find this useful.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
- Capstone
I've altered the design somewhat in the original post, so if someone would convert it to a DXF that would be a big help. seed my "EDIT:" note for details.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
Phil
I did convert it back on the 30th I did find some double lines and extra nodes in the original that I removed.
When you edited the original post did you change the SVG file?
- Capstone
Yes, I revised the original file and removed the old one. SheetCAM deals with double lines etc with .svg's. yet another reason I don't use DXF if I can help it.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
I agree with the SVG file format but someone asked for the DXF conversion.
- little blue choo
GIVE ME SVG every time.
Rick
Rick
Rick
2X2 Shop built table,proma thc,TB6560 bob
TD cut master 52,SL 100 machine torch
mach3, sheetcam, 26cfm compressor, Ref.air dryer, water seperator, motorguard toilet paper filter
Just curious, but what are the reasons some prefer Svg. over Dxf.?
Sorry for the hijack.
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
2015 Autocad lt
Mach 3
Central California
SVG seems to be more fluid and less nodes, better for art type drawings IMHO
- Craig
Thanks Phil, this will be very useful.
Craig Johnson
- steel 35
In for the updated version!
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
Very cool idea - I'm always in awe with what you guys and gals come up with!
Cheers,
Matt
Cheers,
Matt
Custom LDR Motion Systems 5x10 table w/ rotary axis and scribe
Hypertherm Powermax85
Quincy 325 compressor
Ingersoll Rand D18IN refrigerated air dryer
Millermatic 251 MIG
Everlast PowerPro 256 TIG/stick/plasma w/ water cooler
Millermatic 251 MIG
