gift for my brothers
Here are 2 plaques I did for my brothers for the attended collage teams little state rivalry.
Re: gift for my brothers
Those are nice Tom. How are you attaching the layers? I would think two sided tape would take forever to do with all of those small parts.
- SeanP
Nice job Tom, very neat!
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
I used Loctite super glue professional Liquid I bought at a craft store. It is a little thicker and has a good applicator for small dots of glue. But I am not sure how well it will work if the plaque is flexed I don't like how brittle super glue is under some conditions.
There is a better glue called Goop it is like RTV but does not smell as bad what I don't like is it is stringy. I tends to have small strings attached when you put a dot down and move away. But is is very flexible and grips very good holding parts together. I used it on plaques that have bigger parts. I have used the double sided tape to and it can be time consuming but works great. I fully paint both sides before assembly.
- Craig
- edclayton1
That looks awesome. Very cool work.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
Very nice!
Mark
Hypertherm PM 45
Delusional Designs 4x4 CNC
Millermatic 211 welder
Hypertherm PM 45
look up some stuff called silkaflex its a cross between liquid nails and silicone, has a little flex. I've used it for attaching aluminum paneling to steel frame work on custom campers
home made 4x4 water table with ppllc gantry
candcnc dthc2
powermax 85
mach3/ sheetcam/ bendtech sm
candcnc dthc2
powermax 85
They have it at HD may need to try it out silkaflex
Thanks for the tip.
Thanks for the tip.
- little blue choo
I looked up Silkaflex and they offer 37 different products under the name Silkaflex. Which one are you using mexrunner?
Rick
Rick
Rick
Arclight 9600 4x8 table
- little blue choo
After a little research I found this. SikaBond Universal. It's rated to bond non porous materials like metal and glass.
http://usa.sika.com/en/construction-sea ... 7sa01.html
Rick
Rick
Rick
Sika is a very established brand name which has been around for years and has many products for many applications including the adhesives to bond many of the late model vehicles together. Most OEM builders use it extensively for fixing anything from the trim to windscreens to fitting the roof skins to the structure but they use a specific one for each application.
The ones that I use most are 221 and 11FC which are two different grades of flexible adhesive sealants. These are both urethane's which are moisture cure and high strength which remain flexible and can be painted. When adhering powder coated items their data sheets will tell you to use a Sika primer as well. On some off the record advice from one of their tech guys who used to call on us, we used GP thinners to give it a quick wipe, this would remove the greasy surface coating that you get with powder coating (the thin film that shows your finger prints etc.) to provide the key for the adhesive to bite.
Murray
Murray
- little blue choo
Thanks Muzza. I'll give it a try.
Rick
Rick
Rick
