Cabin table order
- Zippo
Cabin table order
One of the cabin tables that were ordered, branded the wood image..
- Attachments
- Img_2902.jpg (20.85 KiB) Viewed 3056 times
- Img_2900.jpg (16.13 KiB) Viewed 3056 times
- Img_2898.jpg (16.88 KiB) Viewed 3056 times
Re: Cabin table order
Really nice idea and it looks great
What is approximate size
Omax 80X Waterjet 6 x 12 with Tilt-A-Jet
CamFive 150w Co2 Laser
Miller Mig & Tig
Whitney-Jenson 20 ton Punch Press
Atlas Lathe
Miller Mig & Tig
Atlas Lathe
That looks awesome what do you use to seal the wood? Is there any chance i could get the dxf for the legs without the art work of course.
- Zippo
Seal it with an 2 part polyurethanewickedinhere wrote:That looks awesome what do you use to seal the wood? Is there any chance i could get the dxf for the legs without the art work of course.
- Zippo
On anything over 11g i put an stress relief cut on the tabs for easier hand bending. also i bend the top and bottom tabs opposite directions for easy stacking Here an standard layout which keeps it stable and both blanks. Couple three examples of cuts i have done, also do military logo and all wildlife
- Attachments
- legs large 2 bg.DXF
- pt 2
- (27.33 KiB) Downloaded 197 times
- legs large 1 bg.DXF
- pt 1
- (27.18 KiB) Downloaded 184 times
- legs large 1 bg standard layout.dxf
- Standard layout
- (152.03 KiB) Downloaded 184 times
- pine cone
- pine cone.jpg (24.8 KiB) Viewed 2963 times
- loon
- LOON LEGS.jpg (28.99 KiB) Viewed 2963 times
- Bear
- bear legs.jpg (24.81 KiB) Viewed 2963 times
Thanks a million i have been looking for a base for a table i was wanting to build.
Very cool table. I could sell a ton of those here in Michigan.
nice work!! How did you brand the wood?
Thanks for the post,
Jim
Jim
Fantastic! Thanks for the files.
Awesome work looks great wondering how much for something like that.
- Zippo
Do it two ways..james.davis wrote:nice work!! How did you brand the wood?
Jim
1) simple brand iron, well just an rod welded on w/reverse pattern
2) lay an pattern an torch around it for different effect.
actually use an weed burner....quicker
- Zippo
starting range from 350 up, depends on detail requested and what sorta top..quadboy wrote:Awesome work looks great wondering how much for something like that.
log, steel, and do an octagon cut out of bonded 2"x 12" drops.
example did an custom round steel Chinese checkers top w/scroll designed legs $1500
as anything custom work really has no set price.
Simply find out what they are looking for and in what price range.
Awesome thank you
Awesome!!
Beautiful!
