It tolls for me! I've been wanting to do a bell for a long while, and everything came together today!
CopperFX base, CopperFX bronze, 3/16 copper rivets
Brass highlight is etched with a carbide burr, heated with a torch and scrubbed with a brass wire brush to transfer a layer of brass to the steel.... After the patinas, I went back over the brass area and copper rivets with a small brass brush to clean off the bronze, and gave it a nice clear powdercoat. It rings like crazy!, sounds like it's resonating for 5 minutes!
The hanger is 3/8" cold rolled bar, and given a bark texture complements of the forge, power hammer and generosity of Plain Ol' Bill.... Thanks Bill!
I used my forge today to draw out the end and form the hook, and brace. I hit this with CopperFX and just lightly touched the corners with BronzeFX. A note on the bronze, I always hit it quick and rinse, then after air drying, depending on the finish I want, I either go over the bronze very lightly with a green scrub pad, or just a dry cotton loop towel to even it out and blend it together.
This was the second bell I've done, and I'm really happy with it... I learned a lot, and the next few will be even better!
Oldsarge
For whom the bell tolls...
- Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
- cstroke
Re: For whom the bell tolls...
Thats pretty cool, thanks for sharing.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
I assume the bell i an old cylinder you cut.
Looks great thanks for sharing.
