Route 66 plaque
Route 66 plaque
Here is a special order I have been working on. The outside plaque is 18" tall, the center about 12". Both are flamed colored and then clear powder coated. The stand offs are threaded studs welded to the back using a stud welder. I will cover up the studs and nuts with some black tubing. First time using the stud welder, worked great. Lot's of ideas for new projects.
- Attachments
- IMG_0857.JPG (56.06 KiB) Viewed 989 times
- IMG_0853.JPG (118.98 KiB) Viewed 989 times
