It is currently Mon Sep 24, 2018 12:01 am
JD2 MAD Series use SigmaNEST Software
JD Squared plasma table discussion forum
JDSquaredInc
Postby JDSquaredInc » Tue Oct 11, 2016 3:41 pm
**** NO LONGER COMES WITH MAD SERIES TABLES****
JD Squared MAD Series Plasma Cutting Tables use SigmaNEST Software
SigmaNEST Companion Edition (a $4950 value) is included in the purchase price of every MAD Series plasma unit. Easily import drawing files, create nested layouts, and post the necessary G-Code to the machine.
Features
* Wizard-based prompts
* File import - DXF
* True shape nesting
* Automatic path generation
* Automatic NC code generation
Task Parameters
* Material type
* Sheet quantity, length, width, thickness
* Part clearance
* Edge distance
* Torch quantity and spacing
* Minimum torch distance
* Machine type, reference
ToolPath Creation
* Block size
* Sort method (typewriter or zigzag)
* Path direction
* Kerf in control or computer
* Kerf lookup option
* Kerf radius and diameter
Companion users have the flexibility to load DXF files or choose from more than 190 standard shapes in the SigmaNEST library. After creating a parts list, parts can be deleted or edited according to a task’s unique requirements. Automatic nesting of all parts quickly gives users the most efficient layout, at a simple click of a mouse.
Last edited by JDSquaredInc on Tue Mar 27, 2018 12:23 pm, edited 2 times in total.
Ryan Miles - Sales & Marketing
JD Squared, Inc.
Phone: (423) 979-0309
https://www.jd2.com/
Facebook: https://www.facebook.com/JDSquaredInc/
JDSquaredInc
Re: JD2 MAD Series use SigmaNEST Software
Postby JDSquaredInc » Tue Oct 18, 2016 10:36 am
SigmaNEST videos we made:
Cutting parts: https://www.youtube.com/watch?v=l0bow3zPWjY
Import multiple parts: https://www.youtube.com/watch?v=ijXImvgfFMM
SigmaNEST part manipulation: https://www.youtube.com/watch?v=W5Cqcuc2waw
JD Squared, Inc.
Black Forest
Postby Black Forest » Wed Oct 19, 2016 11:11 am
Does SigmaNest actually control the machine or is it just the CAM side of the equation? In other words does the SigmaNest do the job that lets say Mach3 or linuxCNC would do or is there something else at work here?
JDSquaredInc
Postby JDSquaredInc » Wed Oct 19, 2016 2:10 pm
Black Forest wrote:Does SigmaNest actually control the machine or is it just the CAM side of the equation? In other words does the SigmaNest do the job that lets say Mach3 or linuxCNC would do or is there something else at work here?
The SigmaNEST is just a CAD / Nesting software that takes a .DXF and converts it through the post to Gcode. There is our software / GUI that then uses the Gcode to operate the table.
JD Squared, Inc.
Black Forest
Postby Black Forest » Wed Oct 19, 2016 3:15 pm
So jd2 has written it's own machine controlling software or are did you write a user gui for something already in existence.?
JDSquaredInc
Postby JDSquaredInc » Wed Oct 19, 2016 3:37 pm
Black Forest wrote:So jd2 has written it's own machine controlling software or are did you write a user gui for something already in existence.?
The controls are a combination of us and Machine Kit. The GUI of the controls is ours.
JD Squared, Inc.
Flyer5
Postby Flyer5 » Wed May 31, 2017 7:55 pm
We purchased our table in early February 2017. Why was sigma nest not part of our package? Why the change?
We received sheet cam instead.
StSweeper
Postby StSweeper » Thu Sep 14, 2017 2:50 pm
Also curious why it did not come with SigmaNest software. The sheet cam only has 3 basic shapes so you cannot even generate circles without using a 3rd program as well as cutting off corners.
Sam Gooden
Postby Sam Gooden » Thu Nov 09, 2017 4:40 pm
St sweeper what have you done to solve your problem I just got one and same issues
Return to “JD Squared”
