It is currently Wed Jul 18, 2018 4:08 pm
LINCOLN Pro Cut 55 Experience
Discussion forum for Lincoln & Miller plasma cutters
hdfaster
Postby hdfaster » Sat Jan 09, 2010 5:54 pm
Some one has to be the first. I am new to this community but not to CNC PLASMA CUTTING. I have had a LINCOLN PRO-CUT 55 hooked up to my Plasmacam for 8 years now and have had no problems with the Lincoln. I do mostly Stainless, Brass, and Copper. I cut Aluminum and steel but to a lesser degree. The plasmacam with DHC has been very reliable. I do not have a business so I don't use it nearly as much as others have. I bought the pro-cut 55 because I could run consumables from the pro-cut 25 which has a .028 orfice. I have to turn the AMPS all the way down to 25 AMPS but get fine cuts with very good quality. Its slower but like I said, I am not in business.
RONALD BERG
Re: LINCOLN Pro Cut 55 Experience
Postby RONALD BERG » Thu Mar 10, 2011 11:10 pm
howdy--i have a pcam as well and also a pro cut 55------and i am here in puerto vallarta mexico--and haveing a hard tim getting consumables ---did not no you can use a pro 25 consumable --i now use .o43-----and love the idea of using a .o28--are the electrodes the same as well----thanks great info [email protected]
Return to “Lincoln & Miller Plasma Cutters”
