It is currently Tue Aug 21, 2018 3:52 pm
Help wiring a Miller 2050 to DTHC II or plasma table
Discussion forum for Lincoln & Miller plasma cutters
collinmaune
Postby collinmaune » Mon Mar 20, 2017 3:32 pm
I need help wiring my miller 2050 to my CandCNC DTHC II
Dana gear
Re: Help wiring a Miller 2050 to DTHC II or plasma table
Postby Dana gear » Tue Mar 21, 2017 8:45 pm
The Miller 2050 is a good plasma power source , however I don't think it was ever shipped from Miller for CNC use.
The trigger circuit would be easy to do.
O.K. to move signal will most likely require a hall devise or reed switch sensing on the work cable this can be added into the machine itself.
Raw arc voltage, voltage feed back can be picked up easily within the machine.
You may want to contact http://www.millerwelds.com
The tech guys there can get you going on this.
Return to “Lincoln & Miller Plasma Cutters”
