It is currently Tue Aug 21, 2018 3:50 pm
proma thc and 60s plasma cutter
Discussion forum for Everlast & Longevity plasma cutters
ScottLister
Postby ScottLister » Mon Jun 25, 2018 8:19 am
I have a 60s plasma cutter and a proma thc. I removed the jumper to obtain the 1/50th divided voltage but I am getting nothing on my thc. My table manufacturer said to use the raw arc voltage with a 100k resistor to fix the problem. When I read in the everlast manual it says the raw arc voltage is already coming through 2 100k resistors. My question is do I need to install another 100k resistor or can I just connect to the raw arc voltage pins on the cpc connector? Any help would be appreciated.
Scott
Rodw
Re: proma thc and 60s plasma cutter
Postby Rodw » Wed Jun 27, 2018 4:06 am
There is an error in the Everlast documentation. See this thread
viewtopic.php?f=111&t=23700
I never got this working properly until I joined 2 x 48 volt power supplies together and put 98 volts through the divider board and measured the output with a voltmeter.
Return to “Everlast & Longevity Plasma Cutters”
