It is currently Fri May 25, 2018 5:03 am
Fastcut CNC
Fastcut plasma table discission forum
logger
Fastcut CNC
Postby logger » Thu Feb 04, 2016 2:55 pm
Hello, bought a fastcut cnc with a hypotherm 1650. Having a problem mabye someone can help me out with. I can change mt pierce height on the control but when I piecre any higher than 1/16" the torch will not fire and I get a error failure to establish arc.
So if I am cutting thin guage and pierce at 1/16" everything works fine. But if I go to say .5"thk material and want to pierce .25" above the material the torch will not turn on and I get the failure to establish arc error.
Any I deas?
Gamelord
Re: Fastcut CNC
Postby Gamelord » Thu Feb 04, 2016 10:59 pm
Why do you want to pierce that high? You should be following the cut charts for the Hypertherm and pierce at the proper height. This will not only pierce better, but it will save your consumables and minimize dross. Piercing that high .25 will just destroy your consumables.
Torchmate CAD
BTA Plasma
Re: Fastcut CNC
Postby BTA Plasma » Fri Feb 05, 2016 9:09 am
Gamelord at 100 amps plus you are piercing at .250 +. Are you sure you have the correct consumables in and is your work clamp not getting through to the material?
Re: Fastcut CNC
Postby jimcolt » Fri Feb 05, 2016 9:13 am
You are not being clear. Is the torch actually firing (when the pierce height is at .250"), but not transferring to the plate? (there will be a bright pilot arc at the torch momentarily, then it will extinguish).
If no pilot arc at the torch....is air flowing at the torch when this occurs?
logger
Re: Fastcut CNC
Postby logger » Fri Feb 05, 2016 10:03 am
Jim, the torch is not firing and there is no air coming thru at .25". There is a 8 sec delay then I get a fault that says "Failure to establish arc" Now if I set the pierce height to 1/16" it will cut fine but screw up the tip because I am piercing too low. So I can not get it to pierce any higher than 1/16" what the heck?
GAMELORD what pierce height and setting would use to go thru .5"thk plate @100amps?
logger
Re: Fastcut CNC
Postby logger » Wed Feb 10, 2016 4:14 pm
Anyone? Ideas???
tcaudle
Re: Fastcut CNC
Postby tcaudle » Wed Feb 10, 2016 6:39 pm
It think that unit uses blow back arc start and should fire in the air. The torch has a "start cartridge" (that turns on the air locally rather than back at the plasma unit. It may be that that cartridge needs replacement.
Sorry I don't know much about the actual firing methods of the TD units .I know how to interface to a CNC control but that is not the kind of help you need. I do know that they cut at a lot higher arc gap and typically lower volts than the Hypertherm. You might give TD tech support a call. If you can't fire it manually at the TORCH ON input then its something in the torch
Where did you buy the 101 ?
Re: Fastcut CNC
Postby jimcolt » Thu Feb 11, 2016 8:31 am
Tom.....he is talking about a Powermax1650, Hypertherm.
If there is no airflow at the plasma cutter....that means it cannot start. In most cases it means that the plasma is not receiving a start input (if using a machine torch...the output from the CNC must connect pins 3 and 4 on the CPC interface plug on the rear panel of the 1650.
The big question: Why does it fire at a closer distance, but not at .250" height? I would disconnect the interface cable from the CNC and short pins 3 and 4 on the plasma receptacle of the cnc ....with the torch at .250 height. The torch should fire and postflow should stay on for about 30 seconds after you remove the short. If it fires with manually shorting the start input pins...assume the plasma is ok....and you will need to determine why the cnc/height control is not allowing a start input at a higher pierce height. The plasma torch does not care where it is....it is waiting for a start signal. Jim Colt Hypertherm
tcaudle
Re: Fastcut CNC
Postby tcaudle » Thu Feb 11, 2016 2:25 pm
oops...reading too many posts. Saw a TD 101 mentioned somewhere...
as Rosanne Rosannadana said: "never mind...."
logger
Re: Fastcut CNC
Postby logger » Sat Feb 20, 2016 12:55 pm
Plasma seems to be ok when shorting the pins still will not fire though when you set peirce height to .25"....wtf
Return to “Fastcut CNC”
