It is currently Wed Aug 22, 2018 4:16 am
THC Problem cutting 1/4" Plate
LDR plasma table discussion forum
tnbndr
Postby tnbndr » Mon Jul 18, 2016 8:44 pm
When I am cutting 1/4" plate it pierces and cuts great for a bit then it starts ramping up the torch volts until it looses penetration.
The DTHC is on and it tries to match the preset volts for a little while and then just keeps going up.
Is there a way when I see this happening to adjust the torch volts down?
I have buttons for volts up/down but that adjusts the preset volts which has no effect on the torch volts.
Any help appreciated.
https://www.youtube.com/watch?v=efwP8LDtObs
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Shane Warnick
Re: Problem cutting 1/4" Plate
Postby Shane Warnick » Mon Jul 18, 2016 10:31 pm
Check the work lead / ground clamp. I had hell with my height control, and the longer the cut the worse it was. Turned out to be the connection between the cable and the clamp, more specifically the ring terminal itself. It was broken / cracked and when I pulled the bolt out, and moved it just a hair it fell apart. Greatest thing about the whole deal was how I found it. Let's just say it was hot. As in face of the sun hot. Oh, and I was bare handed. The whole clamp was impressively hot actually. Best I could figure, the increased resistance caused it to heat up, which in turn increased the resistance, and so on and so forth. All of which was twitching my height control out in the process.
I'm not going to swear that's what it is, but it's worth a look.
Shane
tnbndr
Postby tnbndr » Mon Jul 18, 2016 11:41 pm
I will check that out in the morning. I have my work lead bolted to a small C-vise grip so contact with the metal isn't an issue but the wire to the bolt could be.
PM45
Miller 211
RW 390E Slip Roll
SeanP
Postby SeanP » Tue Jul 19, 2016 3:54 am
I had same thing happening a few weeks back, more so on thinner stuff, I maybe had the the rate set a little low, it's set at 29% just now for everything and its going well.
I did manage to save the part at the time with extreme adjustment of the preset volts, not ideal though!
Powermax 45 with Duramax torch.
R-Tech 210 Tig, Jasic 250 mig
Sheetcam, Scanything, Coreldraw X8, Solidworks
Table build gallery
tnbndr
Postby tnbndr » Tue Jul 19, 2016 7:02 am
What rate?
PM45
Miller 211
RW 390E Slip Roll
SeanP
Postby SeanP » Tue Jul 19, 2016 7:47 am
Sorry 'thc rate' settings page, type number and hit enter.
Table build gallery
Brand X
Postby Brand X » Tue Jul 19, 2016 12:06 pm
Your THC settings are in the Hub administrator, with mach not running,..
tnbndr
Postby tnbndr » Thu Jul 21, 2016 8:32 am
Just to follow up on this.
Dan from LDR spent over an hour on the phone with me yesterday running diagnostics on this problem. It turns out a couple of configuration settings got skewed really bad and once we figured that out and put in the required parameters everything seems to be working great.
Today will tell, off to cutting in a bit.
A big shout out to Dan and LDR for great service and support for a two year old table.
PM45
Miller 211
RW 390E Slip Roll
Capstone
Postby Capstone » Thu Jul 21, 2016 11:05 am
Dennis, please share with us what those config issues were in more detail when you can. Quite a few of us continue to see cut quality issues related to DTHC that might get resolved with a little community mindsharing. Thanks
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
tnbndr
Postby tnbndr » Fri Jul 22, 2016 7:47 am
Not sure they are the same for all setups but I will try to remember what they were.
- Tip Saver % was low, changed to 5%
-DTHC settings Upper Volts Fault Limit was at 2048!!! changed to 250
-DTHC sensitivity changed to 16 and
-DTHC tracking changed to 4, both were at zero
-In the HUB utility program the settings for the Z axis DTHC were all wacked -steps per unit was way too low changed to 10,000
max velocity changed to 110 from 300 and acceleration changed to 30 from 20. Also in the top DTHC information section none of the options were clicked on (green).
I took pics of all the screens for reference. See attached.
PM45
Miller 211
RW 390E Slip Roll
SeanP
Postby SeanP » Fri Jul 22, 2016 7:56 am
Phew think I'll stick with parallel port version :)
Sorry I din't realise you were using the ethernet version.
Table build gallery
Capstone
Postby Capstone » Fri Jul 22, 2016 8:58 am
Thanks Dennis, that info is super helpful. I just cut some 1/4in last night and just turned off the DTHC and ran it at book settings and got nice cuts, but I'll compare your settings to mine and see if there are differences for future reference. Our basic components are identical so its always good to have comparisons with other setups.
Phil
CNC Metal Design
JD Squared 4x8
Capstone
Postby Capstone » Fri Jul 29, 2016 2:05 pm
So have you tested things with the new settings. Any further changes made?
Phil
CNC Metal Design
JD Squared 4x8
Brand X
Postby Brand X » Sat Jul 30, 2016 9:56 am
SeanP wrote:Phew think I'll stick with parallel port version :)
Once setup correct.it's about perfect. I have the 3100 model..(mostly factory settings) I really never need to program all the turn off the THC stuff everybody seems to add to SheetCam when using the older version THC.. Once in a while I just edit the S20 code to to S10 to turn the THC off for small circles.. I can add it auto, but not a big issue either way..
tnbndr
Postby tnbndr » Sat Jul 30, 2016 9:08 pm
I have been cutting for about a week now, 1/4" plate , 12 gauge and 10 gauge using my settings derived from running line tests with DTHC off.
Everything is cutting great, in fact I think better than ever which makes me wonder if some of the config settings were jacked for awhile.
PM45
Miller 211
RW 390E Slip Roll
Diesel
Re: THC Problem cutting 1/4" Plate
Postby Diesel » Wed Nov 02, 2016 4:53 pm
Thanks for sharing, Dennis.
This is very good info for folks like me with an CandCNC Ethercut control.
Cheers,
Matt
Custom LDR Motion Systems 5x10 table w/ rotary axis and scribe
Hypertherm Powermax85
Quincy 325 compressor
Ingersoll Rand D18IN refrigerated air dryer
Millermatic 251 MIG
Everlast PowerPro 256 TIG/stick/plasma w/ water cooler
Return to “LDR Motion Systems”
