It is currently Wed Sep 19, 2018 7:08 am
Last Water table build
Postby acourtjester » Wed May 09, 2018 1:01 pm
Here is the last water table I built for a 4' X 8' table, I used a 5' X 10' sheet of 18 Ga steel. I cut 9" off one end and cut and removed from each corner a 4.5" square. I had a sheet metal fab shop bend up the 4 sides to give a 4.5" depth for the water table. Each corner seam was welded and a 3/4" pipe was welded near one corner for a drain valve. The pins for the slates were 5" apart as shown in the image, the first and third cross support started at the edge for the first pin. And the second and forth cross support the first pin started at 5" in from the edge. The pins are 1/4" rod and the slates are 8' X 1.5" X 1/8" flat stock, when slate are mounted form an "S" shape which hold them so there can be not wiggle of the slates. The support frame was 2" X 2" X 3/16" angle and formed a 48" X 92" base for the slates.
Everlast PM 256 tig
Users browsing this forum: Donkey8445 and 4 guests
