It is currently Fri Sep 21, 2018 9:59 am
Plasma torch splash guard
Simko
Postby Simko » Tue Apr 10, 2018 8:27 pm
I don't remember who originally posted this to give credit to, but it works great. Just enough to help with some splashing especially straight up onto the z-axis, but isn't so big to worry much about catching on tip ups. Cut it open and pull out the silicone check valve. $4.75 on Amazon 8-)
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, Linux CNC and SheetCAM
Click here for build post
beefy
Re: Plasma torch splash guard
Postby beefy » Wed Apr 11, 2018 2:29 am
Cheers Simko,
love collecting gadget ideas.
Keith.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
motoguy
Postby motoguy » Wed Apr 11, 2018 3:15 am
I like that idea. I dig the smaller diameter. I may have to pick one of these up and try it tomorrow!
Ironken
Postby Ironken » Mon Aug 20, 2018 7:55 pm
Just put one on my machine. Great idea!
DMoneyAllstar
Postby DMoneyAllstar » Tue Aug 21, 2018 9:42 am
That would me me.
I actually work at FRAM (going on 20yr), so these check valves are always around in our test lab. One day it just clicked in my brain. Not sure any other brand's check valve will work, since this component is 100% made to fit FRAM product and FRAM automation.
I was amazed at how perfectly they fit the Duramax torch. Been using one for 6mo+ on my home table without any issues. When i need to use the laser cross-hairs, I simply pop it off and then back on when setup & ready. You can even see the shield flow holes' reflection on the valve when the torch is lit.
100% will not and cannot sell to anyone, so please don't ask. Just go get yourself a FRAM oil filter. =)
Ironken
Postby Ironken » Tue Aug 21, 2018 4:47 pm
Genius Dmoney! Thank you for sharing.
DMoneyAllstar
Postby DMoneyAllstar » Tue Sep 04, 2018 8:23 am
I actually looked into getting a few hand-fulls of these check valve "splash guards" from the source. No chance. I don't own the tools, so that's that. Period. Only way to get these is to [1] buy a FRAM filter and gut it, or [2] procure the tooling & have the parts molded. Hey...I tried.
Postby acourtjester » Tue Sep 04, 2018 12:58 pm
Thanks for trying, I have watched a video about filters where the guy cut them open for comparison and here is a screen shot of the start of the video showing the internal parts. It seems like only Fram has that style of check valve, Mobil one comes close, so its off to buy a Fram if you want one :) .
Everlast PM 256 tig
cutting$burning
Postby cutting$burning » Tue Sep 04, 2018 5:56 pm
I started using one of these a couple of months ago after reading this post by Simko. All I can say is WOW what a difference it makes. Thanks to DMoneyAllstar for the original post and idea and thanks to Simko for his post as I missed the first one. Also thanks to acoutjester for the pics and info that Fram is the only one shaped like this.
TrinityFabworks
Postby TrinityFabworks » Wed Sep 12, 2018 8:56 pm
I just started using this the other night, and it works GREAT! Thanks again
Users browsing this forum: No registered users and 4 guests
