It is currently Sat May 26, 2018 3:46 pm
Another Small Plasma Table
msimpson99
Postby msimpson99 » Wed Mar 21, 2018 10:34 pm
It's been a while since I posted here. Way back I posted about my small KRMx02 plasma conversion.
This machine has worked very well for making small parts, but I started a new bit of experiments called the CNC Construction Set. These were all about using common parts to build a couple different CNC machines.
My first is a plasma cutter. The first prototypes will have a 12" x 24" cutting envelope. The size will increase as new builds are added.
Here are my very first cuts on the CNC Construction Set plasma cutter. Please note, that I don't yer have a THC or even a initial height sensor attached to the machine.
https://youtu.be/c_0OFB3rn5w
You can see my writeup on the build here:
http://www.kronosrobotics.com/cnccsintro/
msimpson99
Re: Another Small Plasma Table
Postby msimpson99 » Thu Mar 22, 2018 11:49 pm
I just added the new table to the build.
This gives me full access to the full 13"x25" cutting area for this build.
You can see the writeup here:
http://www.kronosrobotics.com/cnccsplasma-table/
msimpson99
Postby msimpson99 » Sat Apr 07, 2018 10:41 pm
I created this Bent Steel Project box to test my little plasma cutter build.
I did a full writeup here:
http://www.kronosrobotics.com/bent-steel-project-box/
It is not a tutorial as this is my very first finger pressed project box and need a lot more seat time to get it perfect. It was a nice test for the machine however.
