It is currently Sun Aug 19, 2018 2:34 am
1200x1200 (4'x4') plasma build
RyanS
Postby RyanS » Wed May 16, 2018 7:13 am
1200 x 1200mm table using Powermax 45XP, LinuxCNC, Mesa electronics, steppers, linear rails (HGR15 a good size? ) and rack and pinion. Magnetic break away mount and floating head.
First part : torch clamp
Re: 1200x1200 (4'x4') plasma build
Postby acourtjester » Wed May 16, 2018 8:22 am
Great start keep plugging along happy days are ahead :D
Everlast PM 256 tig
Rodw
Postby Rodw » Thu May 17, 2018 6:07 am
Looks like a great start Ryan. It took me 3 months to build the Z axis so it won't take long from there!
If you have not bought your rails yet, I'd recommend you get 25mm ones from alibaba/aliexpress. They'll be about the same price as 15mm purchased in AU.
RyanS
Postby RyanS » Fri May 18, 2018 6:51 am
I'm a bit hesitant to buy long expensive it in case of shipping damage. Did you use 25mm on the Z too?
Rodw
Postby Rodw » Fri May 18, 2018 7:09 am
I used 1 x HGR 15 on the Z axis and a short piece of HGR15 for the floating head. If I did it again I'd use 1 x HGR25 on the Y axis (across the gantry) instead of the 2 x HGR15's I used.
These are the HGR25 rails I bought for the table but I only paid USD $350 for them landed.
https://www.aliexpress.com/item/2pcs-Hi ... 4c4dCMaPXD
RyanS
Postby RyanS » Fri May 18, 2018 8:10 am
That's cheap, I'm seeing $750AUD landed
Rodw
Postby Rodw » Fri May 18, 2018 8:46 am
Yes, they are way more expensive now than when I bought them.
I chose them over these guys who I bought my racks and pinions from becasue these were dearer.
https://www.aliexpress.com/store/179766 ... 273eSgifBX
Rodw
Postby Rodw » Fri May 18, 2018 8:56 am
Forgot to mention those guys have their own brand of linear rail and will cut to size. These are 2.0m long
https://www.aliexpress.com/store/produc ... 4246AOMkDD
